Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 46
  1. #21
    Points: 259,399, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,290
    259,399
    100
    Re: HX711 mV/V information needed
    Now, what is wrong in my latest equation?
    As said, the factor of 1.16.
  2. #22
    Advanced Member level 2
    Points: 3,118, Level: 13
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    The factor of 1.16279 is only for my Proteus setup of AVDD 4.3V. For hardware, I will change it based upon the HX711 module's AVDD.
    Here it shows ratiometric operation.
    https://www.analog.com/en/analog-dia...echniques.html
    DOUT or HX711_rawValue = AIN / AVDD
    Is this correct? AIN = AIN+ - AIN-
    If my Capacity is set to 30 Kgs and ADdcResolution is 2^24 then what final equation I have to use to get the weight value using ratio metric operation?
    I thought about using the 1.16279 (which will be set accordingly for each weighing machine based on it's HX711 module's AVDD and Load Cell max output based on AVDD).
    Another question related to HX711 hardware designing.
    In this HX711 internal circuit:
    https://www.sunrom.com/p/loadcell-se...-bit-adc-hx711
    Why should I use the transistor to get AVDD or VREF voltage for the ADC? Why can't I omit the transistor and connect the DVDD directly to AVDD pin and also E+ pin and get 10mV output from my current Load Cell (2mV/V, 1000 Ohms)?
    What is the purpose of the transistor?
    These are my Load Cell's output voltages. See attached images.
    @FvM
    Tell me the super simple equation to get the final weight value.
    Tested and working fine in Proteus. Will test on hardware today.
    The only issue in code is I have to set these values manually based on each weighing scales HX711's AVDD and Load Cell's output value.
    #define AVDD_Recommended 5.0
    #define AVDD_Actual 4.3
    #define HX711_Full_Scale_value_mV_Per_V_For_Gain_128 40 //+/-20 mV/V = 40 mV
    #define Load_Cell_Full_Scale_Value_mV_Per_V_Multiplied_By_Excitation_Voltage 10 //2 mV/V * 5V = 10mV
    See video.
    https://mega.nz/#!eUBjWYgZ!v4c6YKncE...PE2ycRGqGWbwOg
    Proteus Load Cell model displays value as 0 to 100% as it is a general transducer model.
    My Capacity settings is 30.0 Kgs.
    See this video. I am getting exact values.
    18% on Proteus Load Cell model and 5.4 Kgs on 7 Segment display.
    30.0 Kgs * 18% = 5.4 Kgs
    https://mega.nz/#!LQ4GQYIQ!I7SokqHca...7LHD4u_x6viDUg
  3. #23
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    @FvM, Klaus and other experts,
    Of these two codes which one is correct?
    Code - 1
    #define Adc_Resolution 16777216.0
    #define HX711_Full_Scale_Value 40.0	//Channel A, Gain 128, Clocks 25 = +/-20mV = 40mV
    #define Load_Cell_Max_Output   10.0	//Sensitivity = 2mV/V, For 5V Excitation Voltage it is 2mV/V * 5V = 10mV
    #define HX711_Full_Scale_AVDD 5.0	//For Full Scale 40mV AVDD should be 5.0V
    #define Excitation_Voltage    4.3	//Actual AVDD
    weighingScale.weight = (double)(HX711_Read() - weighingScale.noLoadCounts)
                                         * weighingScale.capacityInKgs
                                         * (HX711_Full_Scale_Value / Load_Cell_Max_Output)
                                         * (HX711_Full_Scale_AVDD / Excitation_Voltage)
                                         / Adc_Resolution;
    (40.0/10.0) * (5.0/4.3) = 4.6511
    Code - 2
    #define Load_Cell_Max_Output   8.6	//Sensitivity = 2mV/V, For 4.3V Excitation Voltage it is 2mV/V * 4.3V = 8.6mV
                                         / Adc_Resolution;
    (40/8.6) = 4.6511
    According to me Code - 2 is correct.
    Edit 1:
    Same as Code - 2 but more readable and understandable.
    Code - 3
    #define Load_Cell_Sensitivity_mV_Per_V	 2.0	//2mV/V
    #define Load_Cell_Excitation_Voltage     4.3	//AVDD or E+
    #define Load_Cell_Max_Output		(Load_Cell_Sensitivity_mV_Per_V * Load_Cell_Excitation_Voltage)	//2mV/V * 4.3V = 8.6mV
                                         / Adc_Resolution;
  4. #24
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,290
    259,399
    100
    It's an AVDD regulator, useless in ratiometric bridge configuration if your power supply is at least short time stable and ripple-free. I would connect DVDD and AVDD.
    As long as the load cell is supplied by AVDD, the digital output does not change with varying AVDD. Just use nominal 5V ADC range and 5V load cell sensitivity for your calculations. If actual AVDD is different, both values scale with the same factor. The ADC offset effect increases with reduced AVDD, but it's compensated by your unload measurement.
  5. #25
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    I have a new question.
    Client needs auto-calibration of Load Cell feature. HX711 will be used.
    So, how to get these values automatically?
    I can get AVDD or E+ in runtime using 10-bit ADC of PIC. What about others?
    Edit:
    This value is fixed.
    AVDD or E+ I can get from ADC 10-bit of PIC.
    How to find out Sensitivity of Load Cell for auto-calibration that is I can't put say 2mV/V in code but need to get it when device is first powered and saved it in eeprom. How to do it?
  6. #26
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,290
    259,399
    100
    Auto calibration is only useful with a calibration weight.
    AVDD has no effect on calibration.
  7. #27
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    Yes, I found out that myself.
    I found out the auto-calibration procedure myself. Will post it here after project completes.
    Currently, I am using the max capacity of the Load Cell as the calibration weight that is if Load Cell Capacity is 30 Kgs then I will use 30 Kgs as the calibration weight.
    Auto-calibration process
    This will be hardcoded
    So, for 40mV HX711 output will be 16777216.0
    Now, if rawAdcValue is say 3607101.44 then
    we can auto-calibrate by using
    loadCell.maxOutput (for say 30 Kgs for 30 kg Load Cell) = (rawAdcValue * 40.0) / Adc_Resolution
    loadCell.maxOutput = (3607101.44 * 40) / 16777216.0 = 8.6 (mV)
    This completes the auto-calibration.
    Then I can use this code to find out weight.
                                         * (HX711_Full_Scale_Value / loadCell.maxOutput)
                                         / Adc_Resolution;
    With known lower weight than capacity of load cell
    30 kgs = 3607101.44
    2 kgs = t
    t = (2 kgs * 3607101.44) / 30 kgs = 240473.42933333333333333333333333
    loadCell.maxOutput = (((rawAdcValue * loadCell.capacity) / knownCalibrationWeight) * HX711_Full_Scale_Value) / Adc_Resolution
    Eg:
    If rawAdcValue = 240473.42933 for 2 Kgs known weight, then
    loadCell.maxOutput = (((240473.42933 * 30.0) / 2.0) * 40.0) / 16777216.0
    loadCell.maxOutput = 8.6 //8.6mV
  8. #28
    Points: 77,136, Level: 67
    Apr 2014
    15,627
    77,136
    67
    Mybe the customer means auto offset calibration...
  9. #29
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    No. Only auto-calibration which is done at factory or field by enabling a jumper.
  10. #30
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    I have one more issue.
    I have a parameter named Accuracy for weight. It has three options 1, 2 and 5.
    How to implement these?
    1.	If set the Acc = 1, then machine will increase like (0.000), (0.001) , (0.002) , (0.003) , (0.004) , (0.005) , (0.006) , (0.007) , (0.008) , (0.009, (0.010) Up to (30.000), Every time Increase only 1 number.
    2.	If set the Acc = 2, then machine will increase like (0.000), (0.002) , (0.004) , (0.006) , (0.008) , (0.010) , (0.012) , (0.014) , (0.016) , (0.018, (0.020) Up to (30.000), Every time Increase only 2 number.
    If set the Acc = 5, then machine will increase like (0.000), (0.005) , (0.010) , (0.015) , (0.020) , (0.025) , (0.030) , (0.035) , (0.040) , (0.045, (0.050) Up to (30.000). Every time Increase only 5 number
  11. #31
    Apr 2014
    15,627
    77,136
    67
    For 0.001 you may multiply with 1000, then do the rounding to integer, then divide by 1000
    For 0.002 ... multiply with 500
    For 0.005 ... multiply with 200
    But I assume there are better ways to do this.
  12. #32
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    What are the other better ways?
  13. #33
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    Auto-calibration method is working but I am getting fluctuating weight values (rapid) as my no load counts (value) is fluctuating. What should I do to stabilize the no load counts.
    no load counts = raw HX711 output value when there is no weight.
    In Proteus it works very fine as the no load counts are stable in it.
    Can I connect GND of HX711 module to say -5V and VDD/VCC of HX711 module to +10V to stabilize the no load counts? I guess the noise from power supply is causing the fluctuations.
  14. #34
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    In Proteus the weight value is stable but in hardware, the weight is fluctuating because the no-load value is fluctuating.
    In video, you can see value after CAL screen and that is no load count and it is stable in Proteus as there is no noise in the power supply. In hardware, it is fluctuating and hence I am not getting precise weight reading and also there is a radip fluctuation of weight value.
    How to solve it?
    Video (20 MB)
    https://mega.nz/#!7MAGgYpb!AFMkwX04E...TRkgkVkSygCW5U
  15. #35
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    Client tested it and got accurate results. Weighing Scale working fine now.
    https://mega.nz/#!uAACCA6b!Ptfi4DBGu...Nh4Junl36Xs6Bo
  16. #36
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    The client is telling that with my code a 600gms Load Cell is easily measuring up to 30kgs weight accurately.
    Load Cell Ultimate Overload is 200% and
    Safe Overload is 150%.
    200% of 600gms = 120gms; 720gms (Ultimate Overload)
    150% of 600gms = 90gms; 690gms (Safe Overload)
    He wants to use overloading and save a few bucks. Is that okay?
    I asked him to pay more for adding code to overload other higher capacities.
    I said the Load Cell will get permanently damaged or deformed with overloading.
  17. #37
    Apr 2014
    15,627
    77,136
    67
    200% of 600gms = 1200gms;
    100% = 600g, thus 2 x 100% = 2 Ũ 600g = 1200g.
    But if the client abuses the sensor, then it's not your problem.
  18. #38
    Points: 8,187, Level: 21
    paulfjujo's Avatar
    Jun 2008
    France 01120
    1,321
    8,187
    21
    hello,
    you tell us that before : LoadCell.maxOutput (for say 30 Kgs for 30 kg Load Cell) ?
    what is the range of loadcell 30Kg or other value ?..
    where is the problem except with your own scaling -by amplifier and ) software , maybe to adapt booth
    to mesuring this 30Kg range.
  19. #39
    baileychic's Avatar
    Aug 2017
    622
    3,118
    13
    I will explain with an example.
    Let's say we are using a 30kgs 2mV/V Capacity Load Cell with HX711 @ 128 as gain and 5V as excitation voltage (EV), then
    for 5V EV and 30kgs weight we get 10mV output from Load Cell and HX711 can handle max 40mV (128 gain, 24 clocks).
    So, 10mV x 4 = 40mV and so, 30kgs x 4 = 120kgs.
    So, we can at-least measure 100kgs with a 30kgs Load Cell.
    200% is Ultimate Overload value and 150% is Safe Overload value and so,
    200% of 30kgs = 60kgs
    150% of 30kgs = 45kgs
    So, how about measuring 100kgs with a 30kgs Load cell?
    @paulfjujo
    Implementing it is not the problem. I have option to enter CAP (actual capacity) value and CAPExt (Overload capacity) value. CAP will be used for auto-calibration and CAPExt if >= CAP will be used for weight calculation.
    Note: Assuming the strain curve will be linear for overloaded value.
  20. #40
    paulfjujo's Avatar
    Jun 2008
    France 01120
    1,321
    8,187
    21
    helllo
    the only way is to use 3 or 4 load cell of 30Kg !
    even your measure chain seems to be compliant to get 10mv X 3 or 10mV x 4
    or use a Mechanic way (Lever system) to divide the strenght applied to one load cell, when input is 100Kg
