Results 1 to 3 of 3
    Member level 3
    Points: 753, Level: 6
    Mar 2017
    60
    753
    Power amplifier impedance matching
    Is it possible to match complex impedance to other complex impedance using quarter wave impedance matching technique? And How?
    Points: 258,558, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,138
    258,558
    100
    Re: Power amplifier impedance matching
    You can with multiple transmission line stubs. Obviously not all exactly quarter wave length. Smith chart tools like SimSmith will help you to design the matching network.
    As a simple approach (not necessarily the best), use one shunt stub at each side to compensate the imaginary impedance and a quarter wave series line to match the remaining real impedances.
    Full Member level 3
    Points: 1,131, Level: 7
    Jan 2019
    Belgium
    163
    1,131
    7
    You can but will be limited in the number of impedance that you can create.
    The impedance transformation ratio Z_trans = Zo^2/Z_load
    Zo is typically real. So if you have a capacitive load impedance impedance, it gets transformed to an inductive impedance and vice versa.
