Results 1 to 4 of 4
    Newbie level 5
    Points: 1,540, Level: 8
    Aug 2011
    9
    1,540
    8
    AD9288 is not working in Proteus
    Hello everyone,
    can someone help me please, why the simulation of AD9288 is not working in proteus.
    Thanks a lot
    Points: 81,064, Level: 69
    Apr 2014
    16,442
    81,064
    69
    Re: AD9288 is not working in Proteus
    In real world you need:
    * VCC capacitors
    * capacitors at analog inputs (my recommendation)
    * to connect all inputs (even the unused ones) with useful signals
    * current limiting resistors at the LEDs
    We can't verify ENC frequency, nor the voltage levels.
    Try "normal operation mode", see Table4.
    Common mode input voltage range is off specification.
    Differential mode input voltage range is off specification.
    Newbie level 5
    Aug 2011
    9
    1,540
    8
    Hello, i have tried to connect all outputs and used the normal mode but still no luck!
    Points: 30,100, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,980
    30,100
    42
    Blog Entries
    9
    There is no code on this attachment, of if there is somehow embeeded in the project file, not everybody has this program.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
