Results 1 to 6 of 6
    Full Member level 5
    Points: 2,592, Level: 11
    Jul 2012
    279
    2,592
    11
    Choice of capacitors for DC blocking and 3A AC?
    You will deal with choice and sizing DC blocking capacitors for RF power amplifier.
    - DC voltage on RF transistor is under 48V
    - Frequency is over 10MHz
    - AC Current max 3A sinus
    Is a good choice use 1206 ceramic X7R 100nF 200V, 6 pcs in parallel (500mA over each) or it's a problém?
    Xc for 1pcs od 100nF < 150mOhm for 500mA is power disipation on C under 40mW on 6pcs <240mW.
    Question is how big will be ESR on this type of capasitors?
    I was thinking about 2x 330nF PP WIMA , but they are big.
    Points: 77,123, Level: 67
    Apr 2014
    15,623
    77,123
    67
    Re: Choice of capacitors for DC blocking and 3A AC?
    I see no problem.
    Don't use Xc for power dissipation calculation, only ESR....which should be much less than Xc.
    Fir detailed informations I recommend to consult the datasheet.
    Points: 10,820, Level: 24
    Aug 2015
    1,753
    10,820
    24
    NP0 is a better choice at >10MHz ...
    Points: 259,376, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,282
    259,376
    100
    With effectively no voltage across the capacitor, X7R should be o.k. Major manufacturers have individual datasheets for capacitors, see e.g. Murata 100nF/250V/1206
ID:	154443 Click image for larger version.
    Aug 2015
    1,753
    10,820
    24
    its nearly resonant at 18MHz, so OK at 10MHZ, just, but not any higher, possibly better to have several 33nF ... in parallel
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,282
    259,376
    100
    Choosing the capacitor for exact series resonance is of course possible, but we have to consider the complete circuit. At the end of the day, the capacitor ESL is probably a small fraction of the total circuit series inductance. Using the example capacitor up to 100 or 200 MHz @ 500mA shouldn't be a problem.
