Results 1 to 4 of 4
    Junior Member level 1
    Points: 156, Level: 2
    Mar 2019
    17
    156
    Tech library problem
    I have some problems with the NCSU_TechLib_FreePDK45:
    - I looked for the file divaDRC.rul for the DRC but I did not find it.
    - cadence is not able to integrate the FreePDK45.tf technology file.it shows me an error that it fails to load it.
    I think this is the cause of the problem that prohibits me to visualize the low layers of the layouts of the components to interconnect.
    Is there another tech library that I can download to solve thes issues.
    Points: 8,860, Level: 22
    Apr 2016
    1,860
    8,860
    22
    Re: Tech library problem
    1 - I believe you have to use calibre for DRC with this PDK.
    2 - what error?
    Really, I am not Sam.
    Mar 2019
    17
    156
    the error says that cadence fails to load FreePDK45.tf
    it shows a lot of errors on the CIW
    should I change the hole tech library ?
    If yes, Is there another one that I can download ?
    Apr 2016
    1,860
    8,860
    22
    I have no idea if the file you are using is meant for virtuoso. You say the extension is .tf, but other tools/formats also use that extension. The messages don't give any hints about what is going on.
    If you change the tech library, you change the technology. I can't possibly know if you are allowed to do that. Is this homework? Maybe ask the instructor/boss/support person...
