Digital design of a GPU
adwnis123
Full Member level 4
I am searching information about how a GPU is built inside the chip. I mean, I see that for example NVIDIA jetson nano uses 128-core GPU. I am very curious to learn how these cores are made... Why for example CPUs on embedded (and laptops) goes up to 8-core CPUs (6-cores for laptops) and GPUs goes to 128-cores!! But the information I found on google is very limited! Is there any source/book about this?
Thank you...
a very simple answer is that graphic-related tasks are more vectorized in nature. you can benefit from having many cores, each taking care of a specific portion of the overall graphic you are trying to generate. now compare this to a desktop pc where you are running a handful of tasks at a time. a few cores is plenty, tasks tend to be more serial in nature.
Multiple cores work well only for certain tasks and graphics happens to be one of them. The death of multiple core processing is when your processing depends on the result of other processing and that's a problem that arises in many general purpose programs (think if-then-else). Also users are typically focused on one or a couple things at a time. If humans ran 128 programs simultaneously 128 cores might be useful, but usually not.
On the other hand when a game is drawing a frame the game logic can plan the frame and then safely launch hundreds of cores to draw different parts of it with little need for interaction between them.
