Results 1 to 10 of 10
    Points: 37, Level: 1
    Jul 2019
    37
    dsPIC30F2010 - 30 I/SP restarts at interval of 20seconds for no known reason
    I have a simple code for blinking LEDs in dsPIC30F2010. I am using MPLABX v5.20 and XC16 v1.36.
    I notice the dsPIC restarts at approximately 20seconds. Please, what could be the cause? I have tried on different boards and same result.
    Here is my code:
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    #include <xc.h>
    #include <libpic30.h>
    #include <p30F2010.h>
    _FOSC(CSW_FSCM_OFF & XT_PLL16);
    _FWDT(WDT_OFF);
    _FBORPOR(MCLR_DIS & PWRT_OFF & PBOR_ON & BORV_27 & RST_PWMPIN & PWMxH_ACT_HI & PWMxL_ACT_HI);
    _FGS(CODE_PROT_OFF);
    void main( void )
        TRISEbits.TRISE4 = 0;
        TRISEbits.TRISE5 = 0;
        _LATE4 = 1;
        _LATE5 = 1;                          //used this to know when there is restart
         __delay32(2400000);
        _LATE5 = 0;
        while( 1 )
                 __delay32(2400000);
                _LATE4 = 1 - _LATE4;
                _LATE5 = 1 - _LATE5;          //toggle LEDs
    Xtal is 6MHz external. Is there something I need to turn off or on in the SFRs?
    Points: 29,576, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,838
    29,576
    41
    Blog Entries
    9
    Re: dsPIC30F2010 - 30 I/SP restarts at interval of 20seconds for no known reason
    _LATE5 = 1 - _LATE5; //toggle LED s
    Although at first glance this should work, surely doing a logical inversion by an algebraic operation is not the usual way of toggling a bit. Consider instead of doing a toogle, just forcing to a fixed value, .
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Jul 2019
    37
    I tried all stuff. I just changed it to below as suggested. The restart still happens exactly 20 seconds. It is frustrating.
        __delay32(2400000);
                _LATE4 = 0;
                _LATE5 = 1;
                __delay32(2400000);
                 _LATE4 = 1;
                 _LATE5 = 0;
    I also changed the void main() to int main() with a return 0; still no show.
    I still wonder if there is a register or something else I need to set. The uniformity of interval of the restart is exact, Meaning something internal or by default is resetting.
    Points: 80,991, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,275
    80,991
    69
    I'm not that familiar with dsPIC30 series code but a restart at fixed intervals regardless of the coding strongly suggests a watchdog issue. I assume the line "_FWDT(WDT_OFF);" turns it off, is there another control for the watchdog, maybe in the device config that needs attention?
    Points: 259,288, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,270
    259,288
    100
    Besides code review, you should also learn to read reset reason register.
    Jul 2019
    37
    Strangely, the WDT was the culprit. It remains enabled despite turning it off in the config and confirming that on the programmer config bits too.
    Apply CLRWDT stopped the reset.
    Could a bad chip be the cause or errata issue or something I don't know yet?
    Since I don't have any readout attached yet to the dsPIC30F, I was able to use LED pattern to confirm the cause of reset via the WDTO bit of RCON. Please, is there anyway RCONbits check can be integrated in code to resolve issues automatically besides development test?
  7. #7
    Nov 2006
    Brazil
    8,838
    29,576
    41
    Blog Entries
    9
    Are you sure that the compiler supports this syntax?
    _FWDT(WDT_OFF);
    According to Microchip's datasheet (MPLAB XC16 C Compiler Users Guide DS50002071H.pdf), the correct one for 16-bits microcontrollers seems like being rather that:
    #pragma config WDT=OFF
  8. #8
    Jul 2019
    37
    Quote Originally Posted by andre_teprom View Post
    _FWDT(WDT_OFF);
    Thanks,
    I tried the new config as below with no success. The reset was ongoing unless I use CLRWDT. I believe the chip is bad. I will be receiving new dsPIC from my supplier soon to confirm if it is chip level failure.
    #pragma config FWPSB = WDTPSB_10        // WDT Prescaler B (1:10)
    #pragma config FWPSA = WDTPSA_512       // WDT Prescaler A (1:512)
    #pragma config WDT = WDT_OFF            // Watchdog Timer (Disabled)
    The prescaler A and B setting explains the >10seconds reset interval I was getting. Strange indeed! Let's assume it is chip partial failure.
    I am running at 6MHz and PLL_16 which should be 24 MIPS Tcy = 41.6ns. That means 1 sec delay should be __delay32(24000000) but __delay32(2400000) was the correct value on the physical chip against my math.
  9. #9
    Points: 7,773, Level: 21
    Jan 2015
    1,090
    7,773
    21
    The answer, as so often happens, is in the data sheet. The last paragraph of Section 19.4.2 says that, if you turn off the config bit, then the WDT is controlled by software with the SWDTEN bit. Make sure this is bit is 0.
    Susan
  10. #10
    Jul 2019
    37
    Quote Originally Posted by Aussie Susan View Post
    Susan
    I appreciate your input. This is a useful pointer. However, my test code got that bit cleared as depicted below:
     //read RCON bits for reset conditions
        if(RCONbits.WDTO)
            _LATE4 = 0;
            _LATE5 = 0;
            __delay32(9600000);
         RCON = 0x0000;
    I believe clearing the entire RCON bits does the job of ensuring SWDTEN = 0.
    Update will be made when I receive new dsPIC chips, as I have agreed my dsPIC chip is faulty. It will be interesting to find out.
