Results 1 to 6 of 6
    Full Member level 3
    Points: 995, Level: 7
    Jan 2018
    157
    995
    7
    what is the significance of the transit frequency and maximum frequency of oscillatio
    Hi I know the definitions of these two parameters: transit frequency (fT) and maximum frequency of oscillation(Fmax). fT: Frequency at which current gain become 0 dB, Fmax: Frequency at which power gain becomes 0 dB.
    What I don't know is that which one to use when..is it like I should look at Fmax while designing power amplifiers and fT is for voltage/current amplifiers.
    Also fT and Fmax ,are they defined only for single transistor or can they be calculated for any circuit, which has many transistors in it. Thanks
    Points: 16,321, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,496
    16,321
    30
    Re: what is the significance of the transit frequency and maximum frequency of oscill
    Quote Originally Posted by circuitslave View Post
    fT: Frequency at whi Fmax: Frequency at which power gain becomes 0 dB.
    No.
    Show me your power gain definition.
    Can you surely understand power gain ?
    No.
    fT is useful for frequency divider at most.
    Yes.
    However you can define 3dB bandwidth for any circuit based on any gain which you define.
    Points: 29,961, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,376
    29,961
    42
    fT : The Frequency where the Short Circuited Current Gain drops to Unity of Active Device ( BJT or MOS etc.)
    fmax: Maximum Available oscillation Frequency that is defined by Intrinsic Elements of the Active Device.( see. Guillermo Gonzales )
    Neither fT nor fmax. is a Direct Design Metric of an Power Amplifier. OK, fT should be as much as possible but it's not enough.There are other intrinsic and extrinsic elements to be considered.
    Oct 2006
    Real Homeless
    2,496
    16,321
    30
    Points: 34,278, Level: 45
    Dec 2004
    New England, USA
    4,814
    34,278
    45
    they are only roughly related.
    More important...is the negative resistance of your active device higher in value than the resistance of your resonant tank circuit.
    Full Member level 3
    Points: 1,131, Level: 7
    Jan 2019
    Belgium
    163
    1,131
    7
    fmax is the frequency where the maximum gain of a transistors (maximum gain --> conjugate matching at BOTH input and output) becomes zero. Beyond this point you will be getting lesser power output than the power you put in.
    fT is the transit frequency where the current gain becomes zero. There are relationships between fT and fmax and higher fT of course means higher fmax. Goes without saying that for PA design, the most important metric is fmax.
    fT is more useful for a bipolar amplifier than for a MOSFET amplifier (unlike fmax which is independent of the choice of the particular type of device).
