Results 1 to 7 of 7
    Member level 5
    Points: 1,199, Level: 7
    Jun 2015
    85
    1,199
    7
    Attempting to get a license for feature 'Synthesis' and/or device 'xcvu440'
    I'm trying to synthesize a certain design using Vivado 17.4, but the synthesis was terminated and i have failed message.
    No errors appear but i have this message
    " Attempting to get a license for feature 'Synthesis' and/or device 'xcvu440' "
    Note ( Design is synthesized properly using Xillinx ISE )
    Points: 31,842, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,368
    31,842
    43
    Re: Attempting to get a license for feature 'Synthesis' and/or device 'xcvu440'
    If you are using the Webpack tools Ultrascale parts are not supported for that version of the tools. You need to have a full purchased license.
    Member level 5
    Jun 2015
    85
    1,199
    7
    Quote Originally Posted by ads-ee View Post
    I used "Vivado HLS 2017.4".
    In Xillinx ISE the design is properly synthesized and implemented using " Defense-grade Virtex-6Q", but i cant find this family in vivado i found (Defense-grade Virtex-7Q) but generated "synthesis failed ".
    How can i add this family to vivado "Defense-grade Virtex-6Q" or finding a alternative one.
    Note ( i have tried all families in Vivado and gives the same message".
    ads-ee's Avatar
    Sep 2013
    USA
    7,368
    31,842
    43
    I don't have time to look up the part support for Vivado right now, but the information is available on Xilinx's website, but I don't believe that 6Q is supported in Vivado. Vivado was designed for 7 series and beyond. Everything prior to 7 series is only supported on ISE.
    The synthesis failed message may be due to cores being generated in a different family on a different tool platform. You may have to generate new IP cores in Vivado for V7Q for it to work properly. I vaguely recall being told by the FAE to generate new IP cores when I migrated a design from K6 to K7 years ago
    Member level 5
    Jun 2015
    85
    1,199
    7
    Still have the same problem.
    Points: 8,571, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,279
    8,571
    22
    Blog Entries
    Adding the ads-ee comments from above....
    Xilinx ISE is for Series6 and previous versions of FPGAs.
    If your target FPGA has changed, so should your Xilinx tools also.
    I am pretty much sure Virtex-6Q and the XVCU* will have different Xilinx primitives.
    FPGA enthusiast!
  7. #7
    Points: 38,013, Level: 47
    Jun 2010
    6,888
    38,013
    47
    Without posting the actual errors there is little we can do to help.
    Do you have a full paid licence for vivado or are you just using the web-pack?
