Results 1 to 7 of 7
    Member level 3
    Points: 869, Level: 6
    HasHx's Avatar
    Oct 2016
    Amman
    61
    869
    VGA to HDMI conversion
    I have been working on a project where I need to convert VGA video signal into HDMI, is there any chips for this? i searched a lot and found a couple of chinese manufacturers and was hoping to find something different from that.
    I also would like to know if there is any way to extract audio from HDMI signal and put it on a separate audio connector?
    Thanks.
    Advanced Member level 2
    Points: 5,009, Level: 16
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    593
    5,009
    16
    Re: VGA to HDMI conversion
    Buy one of these:
    https://www.aliexpress.com/item/3276...chweb201603_60
    disassemble it and try to figure out how analog VGA is digitized.
    And this:
    https://www.aliexpress.com/item/1857...chweb201603_60
    is for extraction of digital audio from HDMI.
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
    Member level 3
    HasHx's Avatar
    Oct 2016
    Amman
    61
    869
    Thanks, they are using Chinese chips that I found their likes but i prefer something that can be procured easily and have clear datasheets.
    Full Member level 2
    Points: 1,020, Level: 7
    FlyingDutch's Avatar
    Dec 2017
    Bydgoszcz - Poland
    130
    1,020
    7
    Quote Originally Posted by HasHx View Post
    look how HDMI is implemented on FPGAs (it is basically VGA + TMDS coder). See for example these links:
    https://www.fpga4fun.com/HDMI.html
    https://numato.com/kb/hdmi-output-ex...lopment-board/
    https://electronics.stackexchange.co...-on-fpga-basic
    Member level 3
    HasHx's Avatar
    Oct 2016
    Amman
    61
    869
    Well, guess i will have to go that way probably as I have many side functionalities along with that one. Thanks!
    Do you have any idea about the cost comparison for both methods?
    Full Member level 3
    Points: 1,249, Level: 7
    Apr 2017
    171
    1,249
    7
    You can get some HDMI examples from here:
    http://hamsterworks.co.nz/mediawiki/.../FPGA_Projects
  7. #7
    Full Member level 2
    Dec 2017
    Bydgoszcz - Poland
    130
    1,020
    7
    the cost of FPGA board is higher, but it is one time cost. After buying FPGA board you can use it for many projects. I can recommend you cheap FPGA board proper to implement such HDMI projects:
    https://numato.com/product/mimas-v2-...with-ddr-sdram
    It cost 50 $ (US). Of course, if you want to spend more choice is wide. For example such board:
    https://store.digilentinc.com/nexys-...-applications/
    dedicated to video processing.
    Kind regards
