H-bridge 100khz recommendations
echinata
Newbie level 3
Hello everyone,
Currently i need a DC to AC inverter that will have an output of frequency 100khz.
The input is 12v DC & 0.5A.
This is for wireless power transfer purpose.
The flow diagram :
12 VDC 0.5a > inverter 100khz > tx coil || rx coil > rectifier > load (12v 0.5a max)
1) May i know the recommendation of the MOSFET model that is suitable for this ? pwm will be generated by arduino.
2) Also is there a built H-bridge thingy that i can buy offshelves and just program the frequency ? if so please give me a recommendation of the model.
Thankyou. :smile:
Can you post the schematic diagram of your circuit ?
You can you use ...
a) A Full H-Bridge or
b) A Half H-Bridge or
c) A single MOSFET
Are you designing a LC Resonant circuit?
This example pre-built device, does come with a 12 Volt 700ma (output) option.
Wireless-Charging
Some units are only 40% efficient.
So, the input current would be 1.75 Amps (input) = 700 ma (output) / 40%
Hi, thanks, im looking at option "a". hence i need recommendation for the Mosfet model that can meet the specs :grin:
You should familiarize yourself with what's already available. You can buy these off the shelf, or find chips that do it all and give complete application circuits:
https://www.mouser.com/ProductDetai...moEFRKS8CN2kBqtyK2cG4zygU5qjQifyOufGncf%2BA==
https://www.analog.com/en/design-ce...ise-isolated-dc-dc-converter.html#cc-overview
Hi, i'm wondering if the "IMS-2B" will work ??
its specs is :
Details
Rated voltage: 3V-15V
Rated current: 50 A
peak current: 110 A
switching frequency: 1 K to 200 kHz
