Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 63
    Advanced Member level 2
    Points: 3,530, Level: 13
    Feb 2016
    680
    3,530
    13
    HFSS port 'Port1' does not have a valid reference plane above or below it.
    How to get rid of the following errors :
    planar_marchand_balun (C:/Users/kevin/Documents/Ansoft/)
    EMDesign1
    [error] An error occurred during the mesh generation. Check the message window for additional details. (11:06:56 am Jul 06, 2019)
    [error] HFSS port 'Port1' does not have a valid reference plane above or below it. (11:06:56 am Jul 06, 2019)
    [error] HFSS port 'Port2' does not have a valid reference plane above or below it. (11:06:56 am Jul 06, 2019)
    [error] HFSS port 'Port3' does not have a valid reference plane above or below it. (11:06:56 am Jul 06, 2019)
    Feb 2016
    680
    3,530
    13
    Re: HFSS port 'Port1' does not have a valid reference plane above or below it.
    I have managed to solved all the simulation issues, and make the simulation converged, but the s-parameter magnitude and phase results make the layout looks like not a marchand balun. Why ?
    Note that the via is not visible at the end of each strip for ports 2 and 3. I am still trying to make the via visible
    planar marchand balun
    magnitude plot
    phase plot
    Points: 14,284, Level: 28
    Apr 2014
    2,239
    14,284
    28
    Did you forget the vias to short the end of the line?
    Feb 2016
    680
    3,530
    13
    @volker
    No, I have put the via in place, but it is just not visible. How do I make the via visible in the layout widow display ?
    I have now added the via correctly and the two vias are visible now.
    However, the magnitude and plot simulation results remain unchanged. Why ?
    Apr 2014
    2,239
    14,284
    28
    I am not an HFSS user, but your vias look like circles on the metal layers, not like a vertical connection between the layers. Check what impedance into that line segment you see at DC.
    Feb 2016
    680
    3,530
    13
    See the via parameter dialog setting
  7. #7
    Apr 2014
    2,239
    14,284
    28
    As I wrote: I am not an HFSS user, but I don't see that vertical metal connection. Not in your 3D view and not in your dialog. You just have the circles on the two metal layers. No connection in between.
  8. #8
    Feb 2016
    680
    3,530
    13
  9. #9
    Apr 2014
    2,239
    14,284
    28
    Did I mention that I am not an HFSS user? But this looks wrong to me. For EM simulation, a via requires a conductor.
    Let me repeat: you can check the via if you check input impedance into path at DC. That works in real life - and in simulation as well.
  10. #10
    Feb 2016
    680
    3,530
    13
    I need to figure out a way to do this via impedance checking in HFSS.
    Anyone else had experience checking via connectivity in HFSS ?
    I have changed the material for both via to use FR4 epoxy, but the s-parameter magnitude and phase plots are still in a mess.
  11. #11
    Apr 2014
    2,239
    14,284
    28
    No no no ... wrong!
    I think your misunderstanding is here:
    - If you send PCB data to a manufacturer, you draw a drill hole and during processing, their metal plating will create the via contact.
    - But here you are in EM simulation, no plating of drills is done behind the screnes, and you explicitely need to define a via layer with conductor material to create that connection.
    In all EM simulations tools that I know, we create separate VIA layer with METAL, to make that connection between layers. From your dialog, maybe HFSS creates that via for you, but material must be METAL. Epoxy is wrong!
    Checking the connectivity is easy, just look at S-parameters at DC, as mentioned before. S11 phase will tell you if there's an open or short.
  12. #12
    Feb 2016
    680
    3,530
    13
    I have changed the via material to copper , but the waveform results still do not look good at all.
    The following are the S22 and S33 waveforms.
  13. #13
    Apr 2014
    2,239
    14,284
    28
    Show a plot of S22 phase and S33 phase, so that we can check if the via is there.
    And maybe reduce your model to a simple 50 Ohm tru line, so that you can practice settings of materials and layers. I'm not even sure if you have the backside metalization in place, drawn as a conductor or realized as a PEC boundary condition.
  14. #14
    Feb 2016
    680
    3,530
    13
    backside metalization ? This is a 2 layer PCB.
    See the S22 and S33 phase plots
  15. #15
    Apr 2014
    2,239
    14,284
    28
    Quote Originally Posted by promach View Post
    Sure, 2 layers, and for such microstrip design the bottom layer is a solid ground plane. That's what I meant with backside metalization.
    Your S22 and S33 shows 180° at DC, which is what we expect for a short circuit. So it looks like your vias are ok.
    The gap (spacing) between coupled lines is much smaller in the photo that you showed. In your model, the spacing is much larger, on the order of the substrate thickness.
    Another note: Your line at port 3 is very close to an edge. From your screenshots I can't see if that is the substrate edge, or ground plane edge, or both. I would add some extra margin there (rule of thumb: at least 2 * line width) , so that line impedance works as designed.
  16. #16
    Feb 2016
    680
    3,530
    13
    So, there is no issue with the stackup layer as well as the via settings ?
    And why would phase of reflection coefficient gives 180 degrees for a short circuit ? I forgot the math.
    I will fix the gap spacing between coupled lines as ell as the extra margin for port 3 and see if those solution help.
  17. #17
    Feb 2016
    680
    3,530
    13
    Something else is wrong. The gap sizing between coupled lines is smaller now, but then the s-parameter waveforms still unchanged.
  18. #18
    Apr 2014
    2,239
    14,284
    28
    Reduce the model to a simple thru line and check results. Most likely your feedline are 50 Ohm, so that test should be fairly easy.
    Are you sure you have the correct dimensions for 20mil substrate thickness? I checked the dimensions from your table in #8 and it gives other Zoe/Zoo for these dimension, so it seems the substrate height in the paper was different.
  19. #19
    Feb 2016
    680
    3,530
    13
    wait, where did you get the information to use 4.3 for Er and 1.0 for Mur ?
  20. #20
    Apr 2014
    2,239
    14,284
    28
    ĩr=1 is physics, εr=4.3 is typical FR4 (but not as clearly defined as for good RF substrates, actual value might be as low as 3.9 or as high as 4.7 depending on resin/fibre mixture)
