Results 1 to 10 of 10
    Advanced Member level 2
    Points: 2,242, Level: 10
    Aug 2016
    579
    2,242
    10
    calculating capacitance of transistor gates
    Is it as simple as C= V/Q for this part maximum gate capacitance at 15v would be 119e-9/15 yeilding 7.93nF?
    https://www.st.com/content/ccc/resou...DM00052344.pdf
    Points: 79,050, Level: 68
    Apr 2014
    16,046
    79,050
    68
    Re: calculating capacitance of transistor gates
    I'm not sure what your question is...
    The output capacitance is acting as miller capacitance, thus ...
    * Although the voltage at the gate changes only about 15V
    * the voltage at the output capacitance may change 415V.
    This causes high Q.
    Aug 2016
    579
    2,242
    10
    This causes high Q.
    Hence max gate charge was determined at 415Vds was to obtain Vgs capacitance to obtain peak current which apparently is 7.93nF for 15Vgs at specified Ids.
    Points: 261,937, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,781
    261,937
    100
    I don't understand the purpose of deriving a capacitance value from total gate charge, because there's no physical capacitor representing the charge. The real behavior is better characterized by Figure 8, gate charge vs gate-source voltage.
    Total gate charge can be used to easily calculate the per pulse gate driver energy and average gate driver supply current.
    Points: 7,372, Level: 20
    Dec 2015
    Madrid, Spain
    1,275
    7,372
    20
    The effective input capacitance is calculated as in post #1. You have capacitance curves in the datasheet.
    Points: 40,234, Level: 49
    Mar 2008
    USA
    6,494
    40,234
    49
    Total gate charge is useful to calculate switching losses
    but treating it as a fixed capacitance will not be accurate
    when it comes to transient switching behavior. Be sure
    you want the right things.
  7. #7
    Aug 2016
    579
    2,242
    10
    This was to determine peak Igs current for gate driver which is 7.93nF for mentioned part.
  8. #8
    Dec 2015
    Madrid, Spain
    1,275
    7,372
    20
    Peak current into gate of transistor is simply V_driver/Rgate. No need for any capacitance value.
  9. #9
    Aug 2016
    579
    2,242
    10
    Is Rgate the series resistor between gate driver output and transistor gate?
  10. #10
    Dec 2015
    Madrid, Spain
    1,275
    7,372
    20
    It includes the gate driver's resistance and transistor's internal resistance as well.
