Results 1 to 3 of 3
    Advanced Member level 2
    Points: 3,363, Level: 13
    Feb 2016
    653
    3,363
    13
    Is it feasible to manually draw from scratch a 2-layer PCB inside HFSS
    I am trying to replicate a new planar marchand balun
    Is it feasible to manually draw from scratch a 2-layer PCB inside HFSS ?
    Or should I use external PCB drawing tool such as Kicad or Altium, then import the PCB layout into HFSS instead ?
    Which method is easier to work with ?
    Points: 30,003, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,384
    30,003
    42
    Re: Is it feasible to manually draw from scratch a 2-layer PCB inside HFSS
    Standard PCB packages such as Altium, Kicad etc. cannot draw this type of precise Microwave layouts.
    I would draw this layout in AutoCAD ( or similar CAD program) then import into HFSS as a DXF.
    Points: 258,547, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,138
    258,547
    100
    They surely can. Any tool allows you to enter and edit polygons with exact coordinates. The better question is which tool can it draw comfortably, e.g. using construction functions, geometrical primitives etc.
