Results 1 to 3 of 3
    Advanced Member level 2
    Points: 2,242, Level: 10
    Aug 2016
    579
    2,242
    10
    More current from multi channel opamp buffer
    Would ganging all channels of an LM324 to buffer +/-5v from a dual supply ~25mA per channel cause its high frequency performance to drop? There are specialty buffer opamps but I only need =<1Mhz. This is to measure parasitics of coils and transformers.
    Points: 261,889, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,771
    261,889
    100
    Re: More current from multi channel opamp buffer
    Consider that paralleled OPs will work against each other due to input offsets, drawing excessive current form the power supply.
    Advanced Member level 3
    Points: 6,246, Level: 18
    Feb 2014
    899
    6,246
    18
    Agree but shouldn't be too hard to fix. 1 ohm balancing resistor means 1mA current imbalance assuming 1mV offset while adding 20mV output voltage variation over 20mA load. Maybe that's fine?
    Or gang together 3 opamps with balancing resistors and use the 4th opamp to regulate their output (cascade costs some bandwidth).
    But yes, buying an appropriate buffer amplifier may be the best choice. Be careful with opamp current specs too, many specify typical output current, not minimum.
