Results 1 to 7 of 7
    Advanced Member level 2
    Points: 2,211, Level: 10
    Aug 2016
    578
    2,211
    10
    obtaining thermal rise in diode
    This diode specifies Average Rectified Output Current @ TT = +75C but referencing the If - Vf graph Figure 2 its Vf for 5A is ~1.15v power dissipated is 5.75W and Junction to lead thermal resistance is give as 10 C/W which would cause the junction to rise 57.5C not the stated 75C. https://www.diodes.com/assets/Datasheets/ds16007.pdf
    Manufacturer specified 75C thermal rise for 5A is not accounted for even if its the sum of power dissipation and typical 25C ambient temperature which would be 82.5C. Isn't power dissipation for diodes the product of its forward voltage and average conducted current?
    Points: 77,645, Level: 67
    Apr 2014
    15,737
    77,645
    67
    Re: obtaining thermal rise in diode
    Junction to lead....temperature ruse is 57C.
    Maybe the lead temperature risees by 18C
    Making a total junction temperature rise of 75C.
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    Aug 2016
    578
    2,211
    10
    This diodes junction will be 75C + ambient temperature while averaging 5amps?
    Points: 39,692, Level: 48
    Mar 2008
    USA
    6,412
    39,692
    48
    We call this "sandbagging the spec". Conservative only costs
    the customer money but tends to keep them safe; aggressive
    makes field returns and ruins AOQ statistics.
    There is also that diode I*V(I) is nonlinear and working with
    averages embeds some assumptions about linearity and
    superposition. Which may or may not be true / accurate.
    Average of products being different than product of averages
    in many cases.
    Points: 17,223, Level: 31
    Nov 2012
    3,147
    17,223
    31
    Vf for 5A is ~1.15v power dissipated is 5.75W and Junction to lead thermal resistance is give as 10 C/W which would cause the junction to rise 57.5C...
    You are right, well almost.
    The resistance has two ends; one end will be 57.5C if the other end is 0; if the exposed end is at 20C, the junction will be 77C. That is how I see it.
    In addition, the heat transfer process is like diffusion and is highly non-linear. The thermal resistance is a function of temperature.
    Fig 1 in the datasheet you have attached says that at 5A current, max terminal temp acceptable is 75C. The junction temp will be 75+57=132C! (good for frying an egg)
    Max power dissipation can always be obtained as V.I; the exact power dissipation can always be obtained as the integral of V(t).I(t).dt over a complete cycle.
    Advanced Member level 3
    Points: 7,438, Level: 20
    Jul 2010
    Sweden
    992
    7,438
    20
    @TT = +75C is the terminal temperature. It is in the "maximum" section, so the diode is rated for max 5A when the terminal temperature is +75C.
    Vf @5A according to table 2 is about 1.05V @25C. Power dissipation = 1.05V * 5A = 5.25W
    Temp rise = 10 * 5.25 = 52.5C
    Junction temp = +75C + 52.5C = 127.5C but it will be less since the forward voltage decreases with increasing temp.
    Approximate with -2mV/C so Vf @5A @+125C is about 0.85V.
    Power dissipation = 0.85V * 5A = 4.25W
    Temp rise = 10 * 4.25 = 42.5C
    Junction temp = +75C + 42.5C = 117.5C but it will be a little higher since the temp is less than 125C, so Vf is a little higher than 0.85V.
    Expect the junction temperature to be about +120C when the terminal temperature is +75C and the average current is 5A.
  7. #7
    Nov 2012
    3,147
    17,223
    31
    but referencing the If - Vf graph Figure 2 its Vf for 5A is ~1.15v power dissipated is 5.75W...
    You need to make a steady state approximation.
    What I mean is that all the heat produced at the junction must be dissipated via the terminal ends.
    About 5W of heat must be conducted away from the pads at 75C by radiation, conduction, etc etc...
    Because the junction temp is not directly accessible to the end user, you need to use the terminal temp as the base for all your calculations.
    If you are planning to use the diode at 5A for extended periods, you surely need some healthy heat sinking. Radiation will perhaps help about 1W/cm2 at 75C (guess value)
    But if you increase the pad size, the terminal temp will perhaps decrease but the dissipation will remain the same. You have to get rid of the heat somewhere else somehow.
