How to save PrimeTime command output into a variable in TCL?
majd229
I've used a few EDA tools with their TCL commanders in the past and now exploring PrimeTime.... the regular method seems to not work, not sure why. Can someone explain what's happening?
eg:
% get_pins -filter {is_clock_pin}
{"instance_x/pinX", "instance_y/pinY"}
#initialize p as 0...
% set p 0
% foreach p [get_pins -filter {is_clock_pin}] { puts $p }
_sel244
im trying to print each clock pin in that array.. however all i get is "_sel244". Not sure what this means. Can someone help?
Thanks.
use "echo [get_object_name $p]"
Thank you.
foreach p [get_pins -filter {is_clock_pin}] { puts "[get_object_name $p]\n" }
instX/pinX instX/pinY
They are now printed as 1 single variable, however if I do this command:
{"instX/pinX", "instX/pinY"}
I get an array structure thats comma separated, how can i have my $p loop through each single value inside the output instead of considering the whole output as 1 value?
