Results 1 to 8 of 8
    Full Member level 4
    Points: 1,829, Level: 9
    Jun 2014
    192
    1,829
    9
    Running Deep Learning Based Plant Diseases Recognition
    How can I run:
    https://github.com/spMohanty/PlantVi...art-of-content
    or smoething similar,
    or this:
    https://github.com/saroz014/Plant-Diseases-Recognition
    on Raspberry Pi ? Or something that does plant disease image processing with CNN?
    Thank you...
    Points: 29,872, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,916
    29,872
    42
    Blog Entries
    9
    Re: Running Deep Learning Based Plant Diseases Recognition
    Quote Originally Posted by adwnis123 View Post
    How can I run:
    How about trying to do what is stated on the README.md link and see what comes next?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Full Member level 4
    Jun 2014
    192
    1,829
    9
    Ok, I did:
    git clone https://github.com/spMohanty/PlantVillage-Dataset
    cd PlantVillage-Dataset
    then what?
    To start running commands randomly by luck?
    Nov 2006
    Brazil
    8,916
    29,872
    42
    Blog Entries
    9
    Did you try to run the python command ? Did you see that there is an issue on which others requested to improve the Readme file ? If by experiments and by looking the source .py code you are not able to identify what to do, I would recommend you add your request at the Issue tab on the Git page, as 2 others have done.
    Full Member level 6
    Points: 4,745, Level: 16
    Feb 2002
    321
    4,745
    16
    Have you tried installing tensorflow for PI? https://maker.pro/raspberry-pi/tutor...n-raspberry-pi
    If the speed is inadequate using a PI, you could always plug in a movidius or coral to the PI.
    Junior Member level 3
    Points: 588, Level: 5
    Mar 2017
    Viet Nam
    25
    588
    Quote Originally Posted by eziggurat View Post
    That's right, it just a dataset , you need a framework for Machine Learning like lite tensorflow on the Pi but the learning time will slowd due to CPU core and dont have GPU support.
    Tiep Ngo
  7. #7
    Full Member level 6
    Feb 2002
    321
    4,745
    16
    You won't be learning on a pi but inference. You train on a PC with gpu and deploy the model to the pi. Coral or gpu on the pi maybe enough to perform inference and it is all depend on your model size and precision.
  8. #8
    Mar 2017
    Viet Nam
    25
    588
    Thanks, never try that but it's a good idea
    Tiep Ngo
