[SOLVED] vivado post route simulation problem
sandeep_sggs
Full Member level 2
india
I am trying to perform post implementation timing simulation of attached circuit in vivado 2016.2(). I am able to do behavioral simulation with all the objects visible (pls refer attached eda_bs). But when i start post implementation timing simulation, i am unable to see d[0:7] listed in objects tab(pls refer attached eda_pits).
Anyone can guess the reason?
code:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
entity TV is
    Port ( clk : in  STD_LOGIC;
           en : in  STD_LOGIC;
           rst : in  STD_LOGIC;
           q : out  STD_LOGIC_VECTOR (0 to 7));
end TV;
architecture Behavioral of TV is
component dff is
    Port ( d : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           rst : in  STD_LOGIC;
           q : out  STD_LOGIC);
end component;
attribute keep : string;
signal d:std_logic_vector(0 to 7);
attribute keep of d : signal is "true";
begin
l1: dff port map (d(0),clk,rst,q(0));
d(0)<= clk and en;
l2:dff port map (d(1),clk,rst,q(1));
d(1)<= d(0) and en;
l3:dff port map (d(2),clk,rst,q(2));
d(2)<= d(1) and en;
l4:dff port map (d(3),clk,rst,q(3));
d(3)<= d(2) and en;
l5:dff port map (d(4),clk,rst,q(4));
d(4)<= d(3) and en;
l6:dff port map (d(5),clk,rst,q(5));
d(5)<= d(4) and en;
l7:dff port map (d(6),clk,rst,q(6));
d(6)<= d(5) and en;
l8:dff port map (d(7),clk,rst,q(7));
d(7)<= d(6) and en;
end Behavioral;
Testbench
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY tb IS
END tb;
ARCHITECTURE behavior OF tb IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT TV
    PORT(
         clk : IN  std_logic;
         en : IN  std_logic;
         rst : IN  std_logic;
         q : OUT  std_logic_vector(0 to 7)
    END COMPONENT;
   --Inputs
   signal clk : std_logic := '0';
   signal en : std_logic := '0';
   signal rst : std_logic := '1';
    --Outputs
   signal q : std_logic_vector(0 to 7);
   -- Clock period definitions
   constant clk_period : time := 10 ns;
BEGIN
    -- Instantiate the Unit Under Test (UUT)
   uut: TV PORT MAP (
          clk => clk,
          en => en,
          rst => rst,
          q => q
   -- Clock process definitions
   clk_process :process
   begin
        clk <= '0';
        wait for clk_period/2;
        clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
      -- hold reset state for 100 ns.
      wait for 100 ns;
rst<='0';
en<='1';
      wait for clk_period*10;
      -- insert stimulus here
      wait;
   end process;
END;
  • eda.zip
The signals are getting optimized away. You need to use some attributes (look it up) like KEEP in order to preserve those signals. But unless you have a really good reason to do that, you may degrade performance.
I think i have already used KEEP in the code(please refer the code above). If that is not how it is done, please tell the correct way if possible....technology schematic looks ok(with above code) too....The same design i have tried to simulate using ISE 14.5. It shows all the objects.
It need to see the same on vivado 2016.2.
A synthesis log is always generated by Vivado. Have you checked that thoroughly? That's a fiest check.
Can you see the signal d[0:7] there?
I’m not going to unzip your file, but where is your component “diff”? Is it properly included in your project?
hello dpaul,
this is what i got from the log.
Start Writing Synthesis Report
Report BlackBoxes:
| |BlackBox name |Instances |
Report Cell Usage:
|      |Cell |Count |
|1     |BUFG |     1|
|2     |LUT2 |     8|
|3     |FDRE |     8|
|4     |IBUF |     3|
|5     |OBUF |     8|
Report Instance Areas:
|      |Instance |Module |Cells |
|1     |top      |       |    28|
|2     |  l1     |dff    |     1|
|3     |  l2     |dff_0  |     1|
|4     |  l3     |dff_1  |     1|
|5     |  l4     |dff_2  |     1|
|6     |  l5     |dff_3  |     1|
|7     |  l6     |dff_4  |     1|
|8     |  l7     |dff_5  |     1|
|9     |  l8     |dff_6  |     1|
Finished Writing Synthesis Report : Time (s): cpu = 00:00:20 ; elapsed = 00:00:31 . Memory (MB): peak = 466.059 ; gain = 259.000
Synthesis finished with 0 errors, 0 critical warnings and 0 warnings.
Synthesis Optimization Runtime : Time (s): cpu = 00:00:14 ; elapsed = 00:00:17 . Memory (MB): peak = 466.059 ; gain = 239.672
Synthesis Optimization Complete : Time (s): cpu = 00:00:20 ; elapsed = 00:00:31 . Memory (MB): peak = 466.059 ; gain = 259.000
INFO: [Project 1-571] Translating synthesized netlist
INFO: [Netlist 29-17] Analyzing 3 Unisim elements for replacement
INFO: [Netlist 29-28] Unisim Transformation completed in 0 CPU seconds
INFO: [Project 1-570] Preparing netlist for logic optimization
INFO: [Opt 31-138] Pushed 0 inverter(s) to 0 load pin(s).
INFO: [Project 1-111] Unisim Transformation Summary:
No Unisim elements were transformed.
INFO: [Common 17-83] Releasing license: Synthesis
22 Infos, 0 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:00:19 ; elapsed = 00:00:23 . Memory (MB): peak = 564.609 ; gain = 340.313
report_utilization: Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.031 . Memory (MB): peak = 564.609 ; gain = 0.000
INFO: [Common 17-206] Exiting Vivado at Wed Jul 03 00:12:58 2019...
any help?
Hello barry,
Thanks for your time. I think yes. It is properly included.
That's doesn't look like the complete synth log file.
Look into project_name.runs/synth_1/runme.log
Hello dpaul,
following is the file. Also attaching post implementation simulation snap-shot for reference.
  • runme.txt
Your synth log says there are no timing constraints for your design.
What are you trying to do?
Hello dpaul,
You mean i won't see the objects (d[0:7]) till i give constraints to the design? Actually, i am unable to see d[0:7] in objects tab (Mentioned in the code above)
Timing constraints have nothing to do with the visibility of signals in simulation.
The OP finds a mismatch b/w func sim & post-impl sim. I found out he has no constraints file and still performing post-impl sim. Is it correct to perform a synth & pst-impl sim without design constraints?
There's nothing intrinsically wrong with doing this. It's not necessarily a good idea if you actually HAVE some constraints, i.e., minimum frequency, but it has nothing to do with signal visibility. I'm guessing there's some optimization going on that's removing his signals.
Use the attribute dont_touch on the module instead of keep. Synthesis will adhere to the keep attribute but the implementation tools will ignore it. The attribute dont_touch won't allow a signal to be optimized at all.
I just noticed that the code:
8
d(0)<= clk and en;
d(1)<= d(0) and en;
d(2)<= d(1) and en;
d(3)<= d(2) and en;
d(4)<= d(3) and en;
d(5)<= d(4) and en;
d(6)<= d(5) and en;
d(7)<= d(6) and en;
ends up as:
d(0) <= clk and en;
--            d(0)
d(1) <= (clk and en) and en;
--            d(1)
d(2) <= (clk and en and en) and en;
so the end result is all of the d(#) are just clk and en with an extra LUT delay between each d.
Not sure what the point of this code is, but relying on LUT delays as some sort of delay line detection method is a sure way to end up with a design that sometimes works and sometimes doesn't depending on the placement of logic after implementation.
