Swend
Full Member level 4
- Joined
- May 14, 2019
- Messages
- 237
- Helped
- 10
- Reputation
- 20
- Reaction score
- 9
- Trophy points
- 18
- Location
- Roskilde, Denmark
- Activity points
- 2,304
do you mean your igbt gets short circuit even without giving any pulse?
In this case, put a 1k resistor on Gate emitter across each IGBT. maybe your problem would fix.
I have tried with the resistor, but the gate is not a problem the signals are crisp and clear.
I tried now with a MOSFET, same result, maybe the igbt is not the problem then.
