+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Advanced Member level 5
    Points: 32,326, Level: 43
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,734
    Points
    32,326
    Level
    43
    Translating a FET drive signal up in voltage
    Hi
    We need to switch some PWM dimming FETs on and off. These FETs sit on top of a 100V rail and the driving micro sits at 0V…therefore we need to translate the drive signal up in voltage.
    We can either use a SI8710 digital isolator, or a IRS25752 bootstrap driver. The IRS25752 looks a hands down winner as its cheaper, smaller, and uses less bias current.
    Can you think of any disadvantages of the IRS25752?
    IRS25752
    https://www.infineon.com/dgdl/irs257...53567b388b2839
    SI8710
    https://media.digikey.com/pdf/Data%2...DFs/Si87xx.pdf
    •   AltAdvertisement
  2. #2
    Points: 23,791, Level: 37
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    4,565
    Points
    23,791
    Level
    37
    Re: Translating a FET drive signal up in voltage
    The bootstrap device won't work for static voltages, if that's a concern...
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,734
    Points
    32,326
    Level
    43
    Thanks, yes, we will feed it a high side bias supply.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 258,488, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,127
    Points
    258,488
    Level
    100
    Both drivers need a power supply on top of the 100V rail in this circuit, thus IRS25752 is the cheaper solution.
  5. #5
    Super Moderator
    Points: 76,249, Level: 67
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    15,461
    Points
    76,249
    Level
    67
    Optocoupler, photoMOS, relais...
    Or some kind of switched capacitor circuit...this may avoid extra power supply.
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    •   AltAdvertisement
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,127
    Points
    258,488
    Level
    100
    We should know pwm frequency and load current to decide about appropriate driver circuit.
  7. #7
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,734
    Points
    32,326
    Level
    43
    pwm frequency is 500Hz. Load is just 2 little sot23 fets being driven on/off
  8. #8
    Super Moderator
    Points: 52,321, Level: 55
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    12,829
    Points
    52,321
    Level
    55
    Simple charge pump creates 107V on top of 100V supply rail. Switched by NPN transistor biased by 5V clock signal at 500 Hz. This results in the load getting 7V DC pulses.
    Click image for larger version.
Name:	charge pump clk NPN cap applies 107V to load ref'd to 100V supply rail.png
    Duty cycle and component values can be adjusted to produce a wide range of volt levels. The simulation has the resistors carrying a few mA.
