Results 1 to 1 of 1
27th June 2019, 12:28 #1
- Join Date
- Aug 2011
- Posts
- 2,612
- Helped
- 304 / 304
- Points
- 13,178
- Level
- 27
Avalon MM - using a FIFO with a registered output
I have an Avalon MM interface of which I'm the master.
The data that I want to write to the slave is buffered in a FIFO.
To achieve better timing - I want to use a FIFO with a registered output...but it seems impossible with Avalon MM.
This is because the "waitrequest" Avalon MM signal.
Consider the following scenario:
1. The data bus of the master side uses a FIFO with 2 pipeline stages on the output.
2. The user logic sees the waitrequest signal de-asserted so it starts reading data out of the FIFO.
3. Suddenly the waitrequest signal is asserted and because of the pipeline latency - by the time data gets to the slave it's lost.
I know the AXI standard uses "Register Slices" to handle such scenarios - but what about Avalon ?
Advertisement
Please login
