Results 1 to 15 of 15
    Newbie level 6
    Points: 85, Level: 1
    Mar 2018
    11
    85
    Power Gain and Voltage Gain of LNA
    Hi all,
    I simulated a source degenerated LNA in ADS and I got S21=7(not in dB for now). Now as far as my knowledge S21 is giving the power gain. If I try to extract voltage gain from PG:
    Ri=50ohm, Ro=1.3Kohm(the calculated impedance of the LC tank at fc)
    Does it mean that the LNA multiplies the voltage at its input by 13.5?
    I ran a transient simulation and I got a different number. Why!?
    and what about S21 in dB? dB(S(2,1)) in ADS gives 20log(S(2,1))! shouldn't it be 10log since its about power?
    Points: 16,332, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    Re: Power Gain and Voltage Gain of LNA
    Quote Originally Posted by Kamran1992 View Post
    Your equation is wrong.
    See the followings.
    https://designers-guide.org/forum/Ya...1266168115/1#1
    https://www.edaboard.com/showthread.php?343941
    Yes.
    Points: 13,722, Level: 28
    Apr 2014
    2,141
    13,722
    28
    S-parameters are voltage ratios, not power, so it is 20log ()
    I would expect an LNA to operate at 50 Ohm load, so why do you look at gain into 1.3kOhm load?
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    Quote Originally Posted by volker@muehlhaus View Post
    No.
    S-parameters are ratios of sqrt(power).
    https://www.edaboard.com/showthread....power-waves#17
    https://www.edaboard.com/showthread....=Power+wave#26
    Apr 2014
    2,141
    13,722
    28
    Sweetheart, I knew you would start that discussion again, again, because you love to fill threads with self quotes. Have a great life!
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    This thread is very easy thing, since reference impedances are real number.
    However S21 is a ratio of sqrt(power) not voltage.
    Many people who can not understand S21 correctly report same thing as this thread.
    This discussion has been completely concluded like following.
    "Power Wave Formulation" is described even in a major standard text book.
    Generalized S-parameters are defined by "Power Wave Formulation" in almost all commercial RF Circuit Simulators.
    They give S11=0 at conjugate matched condition.
    So there is no need to further discuss at all.
  7. #7
    Newbie level 6
    Mar 2018
    11
    85
    Thank you all for your replies "pancho_hideboo" and "volker@muehlhaus"
    I've read these topics and many other things on the issue but got more confused and because of time constraints, I can't really go deep into it! So let me say what exactly I want to do and know:
    I have an LNA with LC load resonating at 2.4GHz, The inductor gives 1.3Kohm at fc in order to increase the narrowband gain. The S11 of LNA is good enough(-14dB), but since there is no matching between LNA and the mixer, do I really need to care about S21? In "RF Microelectronics-Razavi" there are design examples without mentioning S21 actually. And now, using which analyze of ADS, I should measure the gain of LNA? for the other stages of the receiver chain, I measured "Vo/Vin" as the gain. The type of gain in LNA should be the same as the other blocks to design AGC.
  8. #8
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    There is no time constraint.
    You have much time, since you are student.
    Simply don’t use S-parameters, if you don’t have much correct RF knowledge.
    Instead of SP analysis, use AC analysis.
  9. #9
    Points: 258,502, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,134
    258,502
    100
    To calculate the gain with source or load impedances different from 50 ohm, you need to take all four S parameters into account. S21 is the gain with 50 ohm source and load impedance (can be expressed as power or voltage gain as you like).
    However, as you are apparently designing the circuit yourself rather than applying an of-the-shelf LNA, why don't you simply determine the gain with actual load impedance in the simulation. You don't need to take the detour over S parameter.
  10. #10
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    It is true for actual measurement using actual Vector Network Analyzer.
    However we can evaluate S21 in simulation even if Rsource is not equal to Rload.
    S21=sqrt(Pload/Pa), Pa is Available Power of Signal.
    He can not understand that Rout=1.3kohm is not required for S21.
    Rsource, Rin, Rout, Rload.
    If you evaluate relation between S21 and VGain, Rsource, Rin, Rload are required.
    VGain=V2/V1
    Pa=E^2/(4*Rsource), Pload=V2^2/Rload
    V1=V2/VGain=Rin/(Rsource+Rin)*E
    V2/E=Rin/(Rsource+Rin)*VGain
    S21=sqrt(Pload/Pa)=2*sqrt(Rsource/Rload)*(V2/E)=2*sqrt(Rsource/Rload)*Rin/(Rsource+Rin)*VGain
    If Rsource=Rload=Rin, S21=VGain.
    I think so.
    Use AC Analysis.
  11. #11
    Newbie level 6
    Mar 2018
    11
    85
    Yes I'm designing the LNA and other blocks myself, that's what I should do. now I realized that I only need S-parameters for S11 of LNA. The confusion was because S21 is expressed as gain in everywhere, then when I simulated in AC analyze gain was something else! So I got stuck between microwave stuff and RF-electronics. And the 1.3Kohm impedance at the output for S21, came from the idea that the output should be high in order to get gain(Lack of microwave information)!
    Quote Originally Posted by pancho_hideboo View Post
    VGain=V2/V1
    This was the straight forward answer. I calculated the voltage gain from this derivation, campared to the AC analyze, both equal with every Rload.
    Thank you "pancho_hideboo" and "FVM" :)
  12. #12
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
    No. S-parameter Analysis is not needed at all.
    You can evaluate all characteristics by AC-Analysis.
    Don’t use S-parameter analysis.
  13. #13
    Newbie level 6
    Mar 2018
    11
    85
    Well yes, it can be done too, using a simple impedance measurement of the input.
  14. #14
    Oct 2006
    Real Homeless
    2,497
    16,332
    30
  15. #15
    Newbie level 6
    Mar 2018
    11
    85
    Why do you approve Agilent but not Cadence? What is the technical problem of Cadence EDAs?
