Results 1 to 6 of 6
    Junior Member level 3
    Points: 955, Level: 7
    Mar 2015
    31
    955
    7
    Any way to make a rounded rectangle non-plated hole in Altium?
    Well Altium has the option to make a pad rounded rectangle but for multi-layer it removes that option and only allows for a slot meaning the sides will always be a semi-circle and i require tighter radius corners.
    Points: 258,558, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,141
    258,558
    100
    Re: Any way to make a rounded rectangle non-plated hole in Altium?
    Think of the non plated hole as a board cutout. There are no limitations for it, except for available milling tools. If you want a radius below e.g. 0.5 mm, clear with the PCB house first.
    Mar 2015
    31
    955
    7
    Yes i know the limitations of the pcb house, they are just gonna route the pcb to the desired cutout. But i can't draw it:/ Board cutout only allows for a polygon to be drawn..no arcs
    ok i think i found a way: board cutout and use shift+space to change mode to 90 degree arc.
    However i would much rather prefer to have it as a footprint which is a shame
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,141
    258,558
    100
    Polygon can include arcs. I guess, you just haven't found how to draw it.
    I don't specifically know with Altium, but all quality PCB tools that I know can include PCB contours in a footprint.
    Mar 2015
    31
    955
    7
    well i dove deeper and indeed there is a way: You go to the footprint editor and you place a polygon poor cutout, and then set it to board cutout. If you use shift+space you can change drawing modes and let you put an arc as well :)
    Points: 30,013, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,386
    30,013
    42
    A hint... Place a SMD Square with Rounded Corners then place a Donut on it with a Drill Diameter smaller than Inner Circle ..
