Results 1 to 3 of 3
    Full Member level 6
    Points: 3,245, Level: 13
    Sep 2010
    India,Bangalore
    341
    3,245
    13
    Display segment issue
    Hi all,
    We are facing an issue in our display segment. Issue is after placing the display inside the enclosure (with PCB), some of the segments are not working in some boards.
    Note: Before placing inside the enclosure, displays are fine and working.
    Attached an image of similar display.
    Our process is,
    1. Component assembly (machine) without display and backlight.
    2. Manual soldering Backlight and then Display.
    3. Loading firmware.
    4. Enclosure assembly.
    Anyone have any idea what could be the issue?
    Thanks in advance.
    ...VIPU (Very Important Person in Universe) ...lol
    Points: 79,964, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,093
    79,964
    68
    Re: Display segment issue
    If it has a backlight I'm assuming it is an LCD. The most likely reason is the assembly process is slightly distorting the display relative to the PCB so they are no longer exactly parallel to each other. If you are using a zebra strip connector (the usual method) a gap may have appeared on one side or the other of the strip causing signal loss to parts of the display.
    Points: 75,662, Level: 67
    Apr 2014
    15,340
    75,662
    67
    Or ESD problem during soldering or assembling...
