Results 1 to 7 of 7
    Newbie level 3
    Points: 44, Level: 1
    Jun 2019
    44
    Design circular antenna array
    how i can design a circular antenna array with 4 rectangular patch elements using HFSS.
    Full Member level 2
    Points: 1,011, Level: 7
    Oct 2017
    140
    1,011
    7
    Re: Design circular antenna array
    If i understand correctly, you are asking about circular polarized array. The following links give some idea:
    https://www.qsl.net/va3iul/Antenna/P...h_Antennas.gif
    https://www.researchgate.net/publica...Antenna_Arrays
    Newbie level 3
    Jun 2019
    44
    thnQ
    I guess this link can help me in practical design but i need some help in design it on HFSS,
    The design i need to apply it as on Jackson Paper
    " Theory, design, and measurement of novel uniform circular antenna arrays for direction of arrival estimation"
    " Brad Jackson
    Bruce Liao
    Sreeaman Rajan
    DRDC – Ottawa Research Centre
    Sichun Wang
    Communications Research Centre Canada "
    how he design the antenna using software this what i need
    Points: 257,348, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,911
    257,348
    100
    Patch antenna uniform circular array is understood in the paper like this (all patches have same linear polarisation)
    Newbie level 3
    Jun 2019
    44
    I know that but when i applied this in HFSS give me an error and the feed was used coaxial.
    am not perfect at HFSS. So I need some helps in steps how design as this model if you know ^_^
    Full Member level 2
    Oct 2017
    140
    1,011
    7
    I think direction of arrival may be analyzed without HFSS, some formulas similar to monopulse angle estimation, to see if it is feasible (spacing, substrate size).
    Use HFSS to design single patch antenna with any kind of port, and maybe put additional 3 dummy substrate rectangles to analyze how it affects radiation pattern.
    I never used HFSS, so not much help here.
  7. #7
    Newbie level 3
    Jun 2019
    44
    thnQ a lot.
    I guess I found the problem but not sure, any way a lot of thanks you give me some ideas.
