Results 1 to 2 of 2
    Member level 4
    Points: 1,184, Level: 7
    Oct 2014
    74
    1,184
    7
    Test a TVS diode in a circuit
    Hi
    I have a TVS Diode(LCDA24) in circuit which can't be taken out. I want to test whether it's OK or not.
    In diode test mode:
    On the first diode, i am getting OL reading when forward and reverse biased between Pin 1 and 8 and so on
    While the other diode shows 1.7V when reverse biased between Pin 1 and 8 and OL when forward biased.
    Points: 23,595, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,527
    23,595
    37
    Re: Test a TVS diode in a circuit
    Not sure what you mean by “ first diode”. These are back-to-back diodes. They should measure OL in both directions, unless you’ve exceeded the zener voltage, which is not likely. Of course, you’re also measuring the surrounding circuitry...
