Results 1 to 10 of 10
    Full Member level 3
    Points: 1,704, Level: 9
    Jun 2014
    177
    1,704
    9
    OV7670 camera interface with Digilent SPARTAN 3E
    What modifications should I use in this VHDL code:
    http://hamsterworks.co.nz/mediawiki/.../OV7670_camera
    in order to make it run on Spartan 3E Starter kit?
    The above code has been written for Nexys2. If I change only the nexys2.ucf file to correspond to the the Digilent Spartan 3E will it work? Should I make any other changes?
    Thank you
    Points: 30,790, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    7,091
    30,790
    42
    Re: OV7670 camera interface with Digilent SPARTAN 3E
    From what I saw at a glance it looks like all the code is synthesizable behavioral RTL and should only require a new UCF file to assign the pins to the equivalent locations on the Digilent board.
    The only issues might be the size of the part if the starter board is a smaller FPGA or if there isn't an interface available or the correct clock frequency on the starter board.
    Full Member level 3
    Jun 2014
    177
    1,704
    9
    Quote Originally Posted by ads-ee View Post
    Is this something that I can configure with software, I mean with the correct VHDL code?
    Thank you
    ads-ee's Avatar
    Sep 2013
    USA
    7,091
    30,790
    42
    Quote Originally Posted by adwnis123 View Post
    Thank you
    Uhh...yes?
    If the part is too small you'll either have to get a different board than the starter board or have to sacrifice features/functions in the design until it fits, i.e. change the VHDL code until the design is small enough and still does something useful that you need. If you can't remove anything from the design then you'll need a bigger FPGA.
    Full Member level 3
    Jun 2014
    177
    1,704
    9
    Spartan 3E has not enough IO pins to connect it to the OV7670. What should I do in this case?
    Also, how do I put a VGA interface in this FPGA:
    http://pldkit.com/xilinx/xmf5
    Thank you...
    Points: 75,658, Level: 67
    Apr 2014
    15,339
    75,658
    67
    The OV7670 needs more than 60 I/O to connect to the spartan? Are you sure?
  7. #7
    Full Member level 3
    Jun 2014
    177
    1,704
    9
    Here:
    https://www.xilinx.com/support/docum...kits/ug230.pdf
    on page 115:
    it shows J1, J2, J4 which I can use... but the sum of these pins is smaller than the pins of OV7670.
    Or do you mean to use: "Hirose 100-pin FX2 Connector, J3" (which I have no experience of this module)?
    Thank you
  8. #8
    Apr 2014
    15,339
    75,658
    67
    I assume you are experienced enough not be afraid to use a new connector.... this is no rocket science.
    Additionally there are several adapter PCBs available.
  9. #9
    Full Member level 3
    Jun 2014
    177
    1,704
    9
    Is there any distributor in Europe that sells 100 pin FX2 Hirose to connect SPARTAN 3E to this:
    https://store.digilentinc.com/fx2-mo...-limited-time/
    I have send around 10 e-mails to different stores/web stores/electronics stores, nobody sells this kind of cables. I will keep trying however. But I thought some one here could give directions..
    Also, does this:
    https://www.ebay.com.au/itm/263980168070?ul_noapp=true
    work for what I need?
    Thank you...
  10. #10
    Apr 2014
    15,339
    75,658
    67
