Results 1 to 5 of 5
    Full Member level 2
    Points: 1,625, Level: 9
    Jan 2014
    143
    1,625
    9
    Series rlc and parallel rlc circuits
    How can the voltage across a capacitor or inductor in a series RLC circuit be greater than the applied AC source voltage? Also for Parallel RLC, how can the current of anyone branch can be larger than the AC source current?
    Please explain to me the mechanism as to how these phenomenon are possible. THANK YOU!
    Advanced Member level 3
    Points: 7,193, Level: 20
    Jul 2010
    Sweden
    950
    7,193
    20
    Re: Series rlc and parallel rlc circuits
    The electrons move back and forth between the capacitor and the inductor.
    Compare this movement with a mechanical pendulum. It can move much more than the movement you used to push it.
    It is the same with the electrons.
    Points: 258,432, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,119
    258,432
    100
    Taking the RLC series circuit as an example, all elements carry the same current, but voltages have different, even opposite phase according to the reactive nature of C and L. The behavior can be best visualized with phasor diagrams. https://en.wikipedia.org/wiki/Phasor
    If you reduce R in the linked diagram and make XR and XC more equal, you'll see that the internal voltage can be a large multiple of the external voltage.
    Full Member level 2
    Jan 2014
    143
    1,625
    9
    How about in parallel RCL? How can a current in any one branch be greater than the source current?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,119
    258,432
    100
    Sure, basically a similar phasor diagram as for series RLC, just flip voltage and current.
