Results 1 to 3 of 3
    Newbie level 1
    Points: 93, Level: 1
    Jan 2019
    St.Petersburg, RF
    93
    How to build current source based on modified Hawland current pump for 150 mA?
    I have a problem with building of the voltage controlled current source with obligatory grounded load. The input control voltage is in the range from 0 to 5 V, the output voltage is up to 20 V and output current on the load up to 150 mA. The load is some semiconductor device( or material), the (light-emitting)diode for example. Other very important requirements are that the load must be grounded, the control voltage on input and the voltages on the output should be measured with respect to the one common point(ground).
    I have already used the modified Howland current pump. The scheme is quite good for output current of 25 mA, but the suitable heat sink was required to protect the OpAmp. Also I have used the unipolar voltage supply of the OpAmp to obtain the 20 V of output. The another benefit of this scheme is that the output current does not depend on the load resistance.
    How to modify the Howland current pump with the grounded load for output current up to about 200 mA (150 required with about 10 -40 mA in reserve)?
    I have found the example of such modification in the Ref. https://www.edn.com/design/analog/44...current-source. The Howland current pump based, with n-channel FET switch.
    Figure from Ref. https://m.eet.com/media/1181840/f1x600.jpg
    I have tried this scheme with OpAmp LM324 and FET IRLB8743, using resistors R1=R2=R3=100 kOhm, R4=104 kOhm, and obtain the output current up to 200 mA by varying of R5 (pot of 5 kOhm) controlling resistor.
    But as I found from the circuit calculations, presented in the Ref, the output current is dependent on the load resistance. Hence, this current source is quite bad.
    It is possible to improve the scheme to resolve this problem and to obtain voltage controlled current source with grounded load for output current up to about 150-200 mA?
    Advanced Member level 3
    Points: 5,118, Level: 16
    Nov 2013
    751
    5,118
    16
    Re: How to build current source based on modified Hawland current pump for 150 mA?
    Quote Originally Posted by DX400v2 View Post
    By the equation from you (I didn't check) if you set R5=R4-R2 it should handle the load dependence.
    I think your input source at Vin has a varying internal resistance maybe. How you generate Vin?
    "Try SCE to AUX." /John Aaron/
    Points: 264,188, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,159
    264,188
    100
    Varying R5 is not feasible if you want current source characteristic. The equations for Howland current source have been frequently discussed at Edaboard, e.g. in this thread
    https://www.edaboard.com/showthread....current-source
