Results 1 to 9 of 9
    Member level 3
    Points: 631, Level: 5
    Apr 2018
    61
    631
    SMPS selection for Big 6-Digit 7-SEGMENTS display as driver
    Each segments use 3-parallel strings and each string is of 6 LEDs.
    Datasheet specify Vf=12v (min) ~ 13.5v(max), If=60mA(max)
    DP uses 5 LEDs string, and Vf=10v(min), If=20mA(max).
    I am choosing 15v SMPS but what current of that SMPS should I choose,
    My openion:
    for one digit, 60*7 + 20*1= 440mA.
    As I need for 6 digit, 440*6 = 2640mA.
    Can I consider 15V and little more than 2.6A, (like 3.4A) of SMPS to operate all digit smoothly. OR 18V 3.4A OR will u suggest others way.
    Tnx
    Points: 24,977, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    24,977
    38
    Re: SMPS selection for Big 6-Digit 7-SEGMENTS display as driver
    Without knowing more about your devices, I suspect you need to provide current limiting resistors (LEDs are current devices). You will have to size your resistors based on what supply voltage you choose. If you choose a higher voltage, then you're just wasting power across the resistors.
    Member level 3
    Apr 2018
    61
    631
    On consideration of 15v PS unit,
    Current limit R=(15-13.5)/0.06=22 OHMS in each segments,
    i will use ULN IC for both anode and cathode driver too.
    then what should be the current rating of driver smps to drive all six digits.
    that i want to buy.
    tnx
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    24,977
    38
    1) Do you really want to drive these at their maximum current rating? Don't you want SOME margin? If you design this for 13.5V drop, and the actual drop is 12V, you're going to overcurrent the LEDs.
    2) You also need to consider the drop of the drivers in your resistor calculation.
    3) You already figured out what worst-case current you need to drive this. Get a supply with a larger rating.
    Advanced Member level 3
    Points: 3,642, Level: 14
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    It is multiplexed and so only one digit will be ON at a time and so the current draw at any instance is max 440mA.
    You should not run LEDs at max ratings. If LED current is max 60mA then it is good to use 40mA.
    So, 40mA * 7 segments approx = 280mA
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    24,977
    38
    Quote Originally Posted by baileychic View Post
    Nobody said anything about multiplexing...
  7. #7
    Member level 3
    Apr 2018
    61
    631
    Ok.baileychic..
    I will put current limit in each segments with appropriate value to limit currnt in each segments.
    is 15V 3.2Amp OR 2.2Amp good selection as power supply unit for driving all 6 digits.
    tnx
  8. #8
    Points: 265,300, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,354
    265,300
    100
    The word hasn't been used yet. But they discussed having anode and cathode drivers, just another word for multiplexed scheme.
  9. #9
    Points: 81,845, Level: 69
    Apr 2014
    16,619
    81,845
    69
    Multiplexed or not .... to get equal brightness you need about the same average current.
    Example:
    With a multiplex rate of 1:3 you need to drive 3 times the current during ON time.
    For sure one needs to take care about display specifications.
    Usual "20mA" LED s can be driven up to 1A pulsed...With a display I assume it's about the same.
