Results 1 to 8 of 8
    Junior Member level 1
    Points: 574, Level: 5
    Dec 2016
    18
    574
    measuring the parasitic capacitance at a certain node in cadence
    is it possible to measure the parasitic capacitance at a certain node in a schematic in cadence??
    Advanced Member level 3
    Points: 5,649, Level: 17
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    743
    5,649
    17
    Re: measuring the parasitic capacitance at a certain node in cadence
    Yes, it is.
    Points: 16,320, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,496
    16,320
    30
    Quote Originally Posted by amr.maghraby View Post
    I don't know what you want to mean by "in a schematic in cadence" at all.
    However Synopsys HSPICE have following.
    .OPTION CAPTAB
    Adds up all the capacitances attached to a node and prints a table of singleplate
    node capacitances.
    Syntax
    .OPTION CAPTAB
    Default 0
    Description
    Use this option to print a compiled table of single-plate node capacitances for
    diodes, BJTs, MOSFETs, JFETs, and passive capacitors at each operating
    point.
    Note:
    When .OPTION CAPTAB is used to estimate the equivalent capacitance of
    the circuit nodes, HSPICE can give a zero capacitance values for some
    nodes when a resistance is connected to that node. The reason for getting
    0 is that the capacitance is a dynamic, frequency-dependent capacitance
    and not a static capacitance. You need to run an AC analysis to see a nonzero
    node capacitance.
    Cadence Spectre also have similar ability.
    https://www.edaboard.com/showthread.php?380999
    Dec 2016
    18
    574
    Quote Originally Posted by Dominik Przyborowski View Post
    Yes, it is.
    can you please tell me how to find the parasitic capacitance in cadence IC 6.1.3
    Quote Originally Posted by pancho_hideboo View Post
    .OPTION CAPTAB
    node capacitances.
    Syntax
    .OPTION CAPTAB
    Default 0
    Description
    point.
    Note:
    node capacitance.
    i have connected a circuit in cadence and i want to know the value of the parasitic capacitance at this node
    my question is wither there is an analysis that could give me the value of the parasitic capacitance at this node?
    Points: 39,312, Level: 48
    Mar 2008
    USA
    6,357
    39,312
    48
    If you include adding minor schematic mods, then I prefer
    to add a shunt pulsed current source, who can inject a
    known small charge (large enough to be seen, small enough
    to be small-signal-ish) and look at the node step voltage
    right at the end of the pulse. Q=CV.
    Any "on" elements will steal from step voltage and you may
    want to apply a little work at determining what went to R
    and what went to C.
    Oct 2006
    Real Homeless
    2,496
    16,320
    30
    What do you want to mean ?
    Describe correctly with correct terminology.
    If you use Cadence Spectre, use "info what=captab" analysis in Cadence Spectre.
    Surely see https://www.edaboard.com/showthread.php?380999
  7. #7
    Jun 2013
    Norway
    743
    5,649
    17
    What would you like to do?
    1. Simulate capacitance at specific node?
    2. Extract capacitance for all nodes?
    3. Read parasitic capacitance from extracted view?
    What views you have?
    What tools you have?
  8. #8
    Points: 8,433, Level: 21
    Apr 2016
    1,771
    8,433
    21
    Mandatory reminder that Cadence is a company. There is no tool called Cadence...
    Really, I am not Sam.
