[SOLVED] Verilog read-file task, unexpected behaviour
wtr
Full Member level 5
Hello all,
The following code is
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
task TSK_READ_FILE;
    integer scan_file;
    reg [7:0] w_or_r;
    integer len;
    reg [31:0] addr;
    reg [31:0] data;
    integer i;
    begin
        while (!$feof(`ORIGIN.TSK_OPENR_FILE.data_file)) begin
            scan_file = $fscanf(`ORIGIN.TSK_OPENR_FILE.data_file, "%s %d %h %h\n", w_or_r, len, addr, data);
            if (w_or_r == "w")
            begin
                // is designed to always be length 1,
                // data needs to be muti-dimensinal otherwise
                for (i=0; i<len; i=i+1)
                begin
                    `ORIGIN.DATA_STORE[3+4*i] = data[31:24];
                    `ORIGIN.DATA_STORE[2+4*i] = data[23:16];
                    `ORIGIN.DATA_STORE[1+4*i] = data[15:8];
                    `ORIGIN.DATA_STORE[0+4*i] = data[7:0];
                end
                // TSK_TX_MEMORY_WRITE_32
                //--  Tag (7:0) tag_;
                //--  Traffic Class [2:0] tc_;
                //--  Length (in DW)[10:0] len_;
                //--  Address[31:0] addr_;
                //--  Last DW Byte Enable[3:0] last_dw_be_;
                //--  First DW Byte Enable[3:0] first_dw_be_;
                //--  Poisoned Data: Payload is invalid if set ep_;
                `ORIGIN.TSK_TX_MEMORY_WRITE_32(
                    `ORIGIN.DEFAULT_TAG,
                    `ORIGIN.DEFAULT_TC,
                    len,
                    addr,
                    4'h0,
                    4'hF,
                    1'b0);
                $display("[%t] : Writing to addr %x is %x", $realtime, addr, {`ORIGIN.DATA_STORE[3],`ORIGIN.DATA_STORE[2],`ORIGIN.DATA_STORE[1],`ORIGIN.DATA_STORE[0]});
                `ORIGIN.TSK_TX_CLK_EAT(100);
                `ORIGIN.DEFAULT_TAG = `ORIGIN.DEFAULT_TAG + 1;
                `ORIGIN.TSK_WRITEW_FILE(addr,data[31:0]);
            end
            else if (w_or_r == "r")
            begin
                `ORIGIN.P_READ_DATA = 32'hffff_ffff;
                //fork
                //TSK_TX_MEMORY_READ_32;
                //-- Tag                 [7:0]    tag_;
                //-- Length (in DW)      [10:0]   len_;
                //-- Address             [31:0]   addr_;
                //-- Last DW Byte Enable [3:0]    last_dw_be_;
                `ORIGIN.TSK_TX_MEMORY_READ_32(
                    `ORIGIN.DEFAULT_TC,
                    len,
                    addr,
                    4'h0,
                    4'hF);
                `ORIGIN.TSK_WAIT_FOR_READ_DATA;
                `ORIGIN.TSK_TX_CLK_EAT(10);
                `ORIGIN.TSK_WRITER_FILE(addr,`ORIGIN.P_READ_DATA);
                //join
                // Only works based on previous
                $display("[%t] : Readback from addr %x is %x   expected: %x", $realtime, addr, `ORIGIN.P_READ_DATA, data);
            end
            else if (w_or_r == "#")
            begin
                $display("Comment detected");
            end
            else
            begin
                $display("ERROR, the stimulus file does not specify if the line is read/write/comment");
            end
        end
    end
endtask
Where file read in is
# FPGA Compile info
r 1 00000140 00000000
r 1 00000160 00000000
r 1 00000180 00000000
r 1 000001A0 00000000
# Next comment
The output in the write out file is as expected, however the transcript window is flawed. I'm getting the following in modelsim transcript window.
# Comment detected
# ERROR, the stimulus file does not specify if the line is read/write/comment
# [ 346888225000] : TSK_PARSE_FRAME on Transmit
# [ 349016289000] : TSK_PARSE_FRAME on Receive
# [ 350968333000] : Readback from addr 00000140 is 00002018 expected: 00000000
# [ 350984327000] : TSK_PARSE_FRAME on Transmit
# [ 353112321000] : TSK_PARSE_FRAME on Receive
# [ 355064282000] : Readback from addr 00000160 is 00000706 expected: 00000000
# [ 355080275000] : TSK_PARSE_FRAME on Transmit
# [ 357208225000] : TSK_PARSE_FRAME on Receive
# [ 359160225000] : Readback from addr 00000180 is 00001704 expected: 00000000
# [ 359176225000] : TSK_PARSE_FRAME on Transmit
# [ 361304321000] : TSK_PARSE_FRAME on Receive
# [ 363256321000] : Readback from addr 000001a0 is 00004c45 expected: 00000000
# Note: some other file/function putting stuff on transcript line.
# Comment detected
# [ 460408333000] : Readback from addr 01600550 is 00000005 expected: 00000000
The problem is after the comment detected, the if statement seems to run through every instance of the comment & generate the "ERROR, the stimulus file ..." . Now I was hoping the fscanf read the entire line in, however now i'm of the opinion that it's only reading in sections that match the % <- character & therefore it has to do multiple scans for %s string to be traversed until the next line.
Does anyone know of a way I can clean up my transcript window for evidence logging?
I think I found the answer to my problem.
When in the
            begin
            end
section, all I need to do is place
            begin
                //$display("Comment detected");
                scan_file = fgets(str, `ORIGIN.TSK_OPENR_FILE.data_file);
            end
This way I'll read to the end of the line, when at the condition comment detected.
Problem I have now is, what happens with str overflows (I've assigned it to reg of size [256*8:0]).
Is there a more elegant way that will read, regardless of size of scan until end of line?
Regards,
Wes
I would just fgetc the first character and determine if you are looking at a comment line (#) a read or write line (r/w) and only parse the lines with an fscanf if the line is a r/w line. Right now it tries to parse lines that are marked # or r/w in the same way.
Your current fix is a bandaid.
You could use an SV sting type instead to avoid the string overflow.
Reactions: wtr
    wtr
