Results 1 to 5 of 5
    Advanced Member level 2
    Points: 2,155, Level: 10
    Aug 2016
    570
    2,155
    10
    can boost converters cause gate loop ringing
    MOSFETs can be very inefficient with insufficient Vgs even if peak current is coming from a capable gate driver but at insufficient voltage.
    Would a high frequency switcher such as this MT3608 cause gate loop ringing or other issues for supplying a gate driver which would output ~5amps peak and ~40mA RMS?
    MT3608.pdf
    An electrolytic or larger MLCC can be added to the gate driver supply rail across the recommended 22uF MLCC filter to handle peak currents.
    Points: 77,053, Level: 67
    Apr 2014
    15,611
    77,053
    67
    Re: can boost converters cause gate loop ringing
    A gate driver delivering too low voltage is simply "unsuitable" independent of it's current capabilities.
    Choose another, suitable driver.
    As the MT3608 is non isolating, you can just use it for a low side MOSFET.
    The use of it makes no sense in my eyes.
    It's input is DC, it's output us DC and both are connected via GND...thus (the DCDC part) it should not be included in the gate loop.
    (Only the output capacitor)
    RMS is not useful here, better use "average" ... and average current should be rather low. It should be equal to
    Q_gate_tot x frequency.
    I assume any electrolytics - with it's high ESR - is not suitable to support the 22uF MLCC.
    Any additional MLCC will not bring much benefit ... because of the low Q that is drawn by every switch ON.
    Points: 259,231, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    To discuss "gate loop" ringing, we should look at the gate driver circuit, not a boost converter data sheet.
    Aug 2016
    570
    2,155
    10
    I meant the mt3608 for lowside switching and didn't include that in the original description.
    It should serve fine for supplying low side NMOS gate driver?
    Member level 3
    Points: 2,053, Level: 10
    Dec 2009
    USA
    54
    2,053
    10
    Quote Originally Posted by Zak28 View Post
    PIN #1 (SW) of the MT3608 is a Low Active MOSFET only, it does not source any current - it is not a Gate Driver - it is the "PWM switch".
    I assume you are trying to add an external MOSFET?
    Please, post a schematic.
    And then clearly explain ...
    How you are going to use the MT3608 to Source current into & Sink current from the Gate of the external MOSFET, without adding a GATE DRIVER?
