Results 1 to 10 of 10
    Member level 5
    Points: 1,162, Level: 7
    Jun 2015
    83
    1,162
    7
    Not enough IOB of a certain FPGA
    I'm working on VHDL coding of a system has two inputs (say input A has 128 bit and input B has 256 bit) i'm using Virtex5. After synthesis Xillinix ISE gives me error that IOB not enough. how can i avoid this problem?
    this is my entity
    ENTITY ro IS
    PORT(RST,CLK:IN STD_LOGIC;
        A      :	IN  std_logic_vector(127 downto 0);
        B	        :	IN  std_logic_vector(255 downto 0);
        C    :	OUT std_logic_vector(127 downto 0));
    END ro;
    Points: 23,776, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,563
    23,776
    37
    Re: Not enough IOB of a certain FPGA
    Um, maybe pick an FPGA that has at least 512 IOB?
    Full Member level 5
    Points: 1,629, Level: 9
    Jan 2019
    316
    1,629
    9
    serial I/O ?
    Member level 5
    Jun 2015
    83
    1,162
    7
    Quote Originally Posted by wwfeldman View Post
    serial I/O ?
    Parallel
    How can i take them serial ?
    and how can i take this in considerations in my code ?
    Full Member level 5
    Jan 2019
    316
    1,629
    9
    Quote Originally Posted by MSAKARIM View Post
    where are you getting 128 bit parallel input, and 256 bit parallel input?
    it takes a lot of PWB space, but 16 74299 type 8 bit universal shift registers would do it
    and you would need to reconvert it to parallel inside the FPGA
    and you would need 32 for the 256 bit datum
    and you would need some circuits to load the data into the shift registers and then shift the data out
    if one is clever, the 32 shift registers can also cover the 16. you would need to add
    multiplexors or tri-state latches to do this
    barry's suggestion of an FPGA with more I/O looks a lot easier
    Points: 76,203, Level: 67
    Apr 2014
    15,457
    76,203
    67
    Are you sure you need
    * 256 input lines and
    * another 128 input lines
    ....and where is the output?
  7. #7
    barry's Avatar
    Mar 2005
    California, USA
    4,563
    23,776
    37
    There’s 128 outputs.
  8. #8
    Points: 258,432, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,118
    258,432
    100
    I fear you are reading too much into the problem. Too me it looks like a trivial FPGA exercise, unfortunately compiled with a too small device, e.g. using automatic device selection in ISE. As long as you are not designing real hardware, where costs and board space matters, just select a device with sufficient number of IOB, Virtex 5 series surely has.
  9. #9
    Apr 2014
    15,457
    76,203
    67
    The text clearly talks just about inputs "a system has two inputs (say input A has 128 bit and input B has 256 bit) "
    A see that the code uses outputs...
  10. #10
    Points: 8,390, Level: 21
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,250
    8,390
    21
    Blog Entries
    Hello OP,
    This looks like an internal module design to me. At the peripheral you don't have these many signals.
    If you provide us the project details then perhaps there can be more help.
    btw - you run a simulation using a testbench for such a model, but for FPGA implementation you have to be realistic with the IO pin count.
    FPGA enthusiast!
