Results 1 to 7 of 7
    Points: 443, Level: 4
    Apr 2018
    45
    443
    Best Solution to use DOT POINT by REVERSING 3rd. one Digit of 4-digit seven segment
    I want to make a RTC clock with 4-digit 7seg disp which will display " HH:MM " in multiplex tech.
    I have 4 nos digit and each are of CA type. As the each single-digit has one DP and which is located on right side of the digit.
    As of " HH. " (H-ten, H-one , .Single Dot) is Ok and I have no problems, But to get one more Dot on upper portion to form remaining " :MM ", I nedd to invert M-ten.
    Sample COUNTER code is here, and tested the digit(SEGMENTS AND CA are connected to ULN Driver IC).
    #include
    //***Define the signal pins of all four displays***//
    #define s1 RC0
    #define s2 RC1
    #define s3 RC2
    #define s4 RC3
    //***End of definition**////
    void main()
    unsigned int a,b,c,d,e,f,g,h; //just variables
    int i = 0; //the 4-digit value that is to be displayed
    int flag =0; //for creating delay
    unsigned int seg[]={0X3F, //Hex value to display the number 0
                        0X06, //Hex value to display the number 1
                        0X5B, //Hex value to display the number 2
                        0X4F, //Hex value to display the number 3
                        0X66, //Hex value to display the number 4
                        0X6D, //Hex value to display the number 5
                        0X7D, //Hex value to display the number 6
                        0X07, //Hex value to display the number 7
                        0X7F, //Hex value to display the number 8
                        0X6F  //Hex value to display the number 9
                       }; //End of Array for displaying numbers from 0 to 9/// FOR CC// FOR CA WITH ULN
    //*****I/O Configuration****//
    TRISC=0X00;
    TRISD=0x00;
    PORTC=0X00;
    //***End of I/O configuration**///
    #define _XTAL_FREQ 20000000
    while(1)
      //***Splitting "i" into four digits***//
    a=i%10;//4th digit is saved here
    b=i/10;
    c=b%10;//3rd digit is saved here
    d=b/10;
    e=d%10; //2nd digit is saved here
    f=d/10;
    g=f%10; //1st digit is saved here
    h=f/10;
    //***End of splitting***//
    PORTD=seg[g];s1=1; //Turn ON 'H-ten'
    __delay_ms(5);s1=0;     //Turn OFF
    PORTD=seg[e];s2=1; //Turn ON 'H-one'
    __delay_ms(5);s2=0;     //Turn OFF
    PORTD=seg[c];s3=1; //Turn ON 'M-ten' >> This digit want to inverse to get the DP upper left side>>
    __delay_ms(5);s3=0;     //Turn OFF
    PORTD=seg[a];s4=1; //Turn ON 'M-one'
    __delay_ms(5);s4=0;     //Turn OFF
    if(flag>=10)
        i++;flag=0;
    flag++;
    My question is,
    should i declare ONE MORE ARRAY with appropriate elements(namely, revese_seg[]) like above //seg[] and load it to PORTD only for this digit..
    PORTD=reverse_seg[c];s3=1; //Turn ON 'M-ten'
    Is that correct process?
    Or can be done something else from Hardware side by changing wire connection of segments for this digit other that software site ?
    Tnx
    Advanced Member level 3
    Points: 6,977, Level: 19
    Jul 2010
    Sweden
    913
    6,977
    19
    Re: Best Solution to use DOT POINT by REVERSING 3rd. one Digit of 4-digit seven segme
    Quote Originally Posted by saramah View Post
    Yes, you can rearrange the connections to the reversed M-ten so it behaves like the other digits.
    Full Member level 4
    Points: 1,150, Level: 7
    Jan 2019
    238
    1,150
    7
    since the colon is always on, or blinks the seconds, why not use a pair of LEDs
    mounted between the hour and minutes?
    then you don't have to rotate minute 10, invent new connections for 0 through 9,
    and the minutes will be as straightforward as the hours
    Apr 2018
    45
    443
    tnx.
    Adding one more array in code is the correct way? or wire rearrange is correct??
    Could u please share some hints about rearrange in hardware connection,
    M-ten Pin:>>      Data-line pin for all three digit(HH: M-one)
    A>>            should it on: DD: D
    B>>            FF: F
    C>>            EE: E
    D>>            AA: A
    E>>            CC: C
    F>>            BB:B
    G>>            GG: G
    Or thers way...
    tnx
    Full Member level 4
    Jan 2019
    238
    1,150
    7
    for a standard 7 segment display, top to bottom
    horizontal A, G, D
    left side F, E
    right side B, C
    decimal point lower right
    for a standard 7 segment display, rotated 180 degrees, top to bottom
    horizontal D G A
    left side C, B
    right side E, F
    decimal point upper left
    0 ABCDEF ABCDEF same
    1 BC EF
    2 ABGED ABGED same
    3 ADGBC ADGEF
    4 GCBF GFEC
    5 AGDBC AGDEF same
    6 DGEF AGBC
    7 ABC DEF
    8 ABCDEFG ABCDEFG same
    9 AGFBC DGCEF
    if you rewire so that B and E are swapped, C and F are swapped, and A and D are swapped,
    the numbers come out correct.
    0, 2, 5 and 8 are correct regardless
    the swap compensates for the rotation
    the decimal point is still the decimal point
    program for M 10 is same as all the other numbers (H 10, H1, & M1)
    Points: 256,089, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,651
    256,089
    100
    Why not simply rewire the segments instead of writing software?
  7. #7
    Full Member level 4
    Jan 2019
    238
    1,150
    7
    I didn't check the power/ground connections.
    So when you rotate M10, you'll have to take care of that.
    It looks like a little re-wiring will solve the problem
