Results 1 to 11 of 11
    Advanced Member level 1
    Points: 4,332, Level: 15
    Jul 2006
    USA
    406
    4,332
    15
    cadence to ADS EM simulation
    I have an inductor from cadence simulation. Can I export the S parameter from cadence and do the EM simulation in ADS? Thanks.
    Points: 30,550, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,481
    30,550
    42
    Re: cadence to ADS EM simulation
    If you have s-parameters of that inductor, why you wanna simulate it in ADS Momentum ?? Or you just want to use those s-parameters in ADSs Co-Simulation ??
    Your question is a bit floating..
    Jul 2006
    USA
    406
    4,332
    15
    Thank you for your reply.
    In Cadence, I want to simulate the two inductors placing very close. I don't know whether Cadence can simulate the coupling effect of the two inductors.
    If Candence can't simulate the coupling effect, then the extracted S parameter is not correct, and converting it into ADS, ADS will not give the coupling effect, right?
    Thank you.
    Points: 17,262, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,661
    17,262
    31
    What do you mean by “Cadence” ?
    Quote Originally Posted by shanmei View Post
    Yes.
    Cadence have design service and device modeling services.
    So Cadence can do any simulation by using almost any vendor tool.
    Points: 14,252, Level: 28
    Apr 2014
    2,234
    14,252
    28
    EM simulation in ADS (Momentum) is based on the layout, not based on other simulation results (S-parameters).
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,481
    30,550
    42
    Thank you.
    Cadence ADE does not have any EM simulator that you need to check the coupling effects of two coils.But you can install Sonnet, ADS Momentum even HFSS to verify your coils.
    In order to do this, you should simplify your circuit and leave two coils alone.Place you EM Ports properly then simulate this layout in EM simulator ,you'll get all information about the coils if they are placed very close.They will act as transformer and you can consider these two coupled coils being as transformer then you may place this n-port element which is defined by s-parameter in your electronic circuit schematic.It will need a bit try-and-cut effort but finally you will get an "insight" how the coils effect your circuit.
    Cadence ADE has effectively a RLCk extraction tools such Assura and Calibre from Mentor Graphics but they are not really effective and accurate as much as an EM simulator.
  7. #7
    Oct 2006
    Real Homeless
    2,661
    17,262
    31
    https://designers-guide.org/forum/Ya...num=1244552575
    Previously Cadence have VPCD(Virtuoso Passive Component Designer), where we can evaluale coupling of inductors roughly.
  8. #8
    Apr 2014
    2,234
    14,252
    28
    Quote Originally Posted by pancho_hideboo View Post
    Do you work in EDA museum? We discussed VPCD end-of-life ten years ago.
  9. #9
    Oct 2006
    Real Homeless
    2,661
    17,262
    31
    I assume you have inductors as PDK.
    So you can get s-parameter of inductor by Sparameter Analysis.
    Here you want to evaluate coulpling between inductors which provided as PDK.
    Answer is no.
    You can not evaluate it by current Cadence Tool Lineup.
    How do you extract S parameter by Cadence Tool ?
    No.
    You can not get S-parameter by any Cadence Tool.
    So your thinking above is completely nonsense.
    You have to use EM analysis tool.
    If you prefer Keysight Momentum on ADS design framework, import layout data to ADS from Virtuoso.
    If you have Momentum integration for Virtuoso, you can do Momentum Analysis directly in Virtuoso environment.
    Quote Originally Posted by volker@muehlhaus View Post
    I know.
    Surely see https://designers-guide.org/forum/Ya...num=1244552575
    However still we can use it in Cadence MMSIM-6.X unofficially.
  10. #10
    Jul 2006
    USA
    406
    4,332
    15
    Thank you for all you reply. Yes, then I switched to the ADS EM simulation. It works for the coupling effect simulation.
    It is weird that Cadence dose not provide good RF simulation enviroment.
  11. #11
    Oct 2006
    Real Homeless
    2,661
    17,262
    31
    See https://community.keysight.com/servl...e+Virtuoso.pdf
