Results 1 to 7 of 7
    Points: 16,029, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,439
    16,029
    30
    Rational Approximation of Gaussian LPF
    I know 5th order Bessel LPF is close to Gaussian LPF.
    But I want to get more close aaproximation as rational function expression.
    My book shows only hint for it.
    Is there anyone who know it ?
    Points: 257,401, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,914
    257,401
    100
    Re: Rational Approximation of Gaussian LPF
    Nuhertz Filter Solutions does a good approximation, slightly lower pole pair Q than Bessel, unfortunately I have no access right now.
    Advanced Member level 3
    Points: 5,634, Level: 17
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    743
    5,634
    17
    The quassi-gaussian filter (bandpass, with quassi-gaussian impuls response) is CR-(RC) ^n, and for n>4 is no big difference.
    The mentioned by you Hurwitz approximation is the only one close to gauss which I know. It might be realized by complex pole 4th order guy. Unfortunately, I have literature to this only in Polish (my colleague master thesis with implementation)
    Oct 2006
    Real Homeless
    2,439
    16,029
    30
    Attached figures show characteristics of Gaussian-LPF and Bessel-LPF in Keysight ADS.
    S(2,1), delay(2,1) : Gaussian-LPF
    S(4,3), delay(4,3) : Bessel-LPF
    I know what polynomials are used for Bessel-LPF.
    However I don't know about Gaussian-LPF.
    What polynomials are used for Gaussian-LPF in Keysight ADS ?
    Jun 2013
    Norway
    743
    5,634
    17
    I have no idea what is used by ADS (i have not touched it even). As I mentioned, the only known for me case is an approximation of Hurwitz polynomials. The odd order polynomials has only complex poles, while even number has an additional real pole. The general formula is as follow (top is odd order, bottom even order):
    where: k is a number of complex poles pairs (for order n=2 and 3 k=1, for n=4,5 k=2, et cetera), σ is related to time constant (or natural frequency of filter), A_i and W_i are polynomial coefficients given for n<5 as following:
    for n=1:
    H(s)=1/(1+s)
    for n=2:
    H(s)=sqrt(2)/[sqrt(2)+sqrt((2)+2·sqrt(2))·σ·s+σ²·s²]
    For higher order I am not sure whether there is a simple values for poles.
    Try to look implement above, maybe it is what you need?
    Good luck!
    Oct 2006
    Real Homeless
    2,439
    16,029
    30
    Thanks for good clue.
    Quote Originally Posted by Dominik Przyborowski View Post
    I think they are opposite.
    Why does top(odd order case) have zero at s=0 ?
    I can calculate Taylor series expansion of exp(p^2), as eq. (13-73) in start of this thread by MATLAB.
    Then I can get zeros of it.
    I choose real(zeros) <= 0.0.
    These are poles for transfer function.
    Later I will build my own custom function for MATLAB.
    function [z, p, k] = my_gaussianap(order, wc, Ac_dB)
    Then I will compare it with ADS results.
  7. #7
    Oct 2006
    Real Homeless
    2,439
    16,029
    30
    I can get same result as ADS.
    function [z, p, k] = my_gaussianap(order, wp, Ap_dB)
    s = tf('s');
    T2 = 0;
    for n = 0:order
        T2 = T2 + (-1)^n * s^(2*n) / factorial(n);
    end
    z = zero(T2);
    p = z( find(real(z) <= 0.0) );
    z = [];
    k = polyval(poly(p), 0);
    s21 = zpk(z, p, k);
    [wc, fval] = fzero(@(wc) dbv( freqresp(s21, wc) ) + Ap_dB, 1.0);
    fprintf(1, 'order=%d, ', order);
    fprintf(1, 'wc=%g, ', wc);
    fprintf( 1, 'Ac_dB=%g, ', -20*log10( freqresp(s21, wc) ) );
    z = (wp/wc) * z;
    p = (wp/wc) * p;
    k = k * (wp/wc)^( length(p)-length(z) );
    s21 = zpk(z, p, k);
    fprintf(1, 'wp=%g, ', wp);
    fprintf( 1, 'Ap_dB=%g\n', -20*log10( freqresp(s21, wp) ) );
