Results 1 to 4 of 4
    Member level 5
    Points: 1,642, Level: 9
    Dec 2010
    Belgium
    87
    1,642
    9
    Setting AA batteries in parallel
    My application currently uses 2XAA batteries in series to have 3 Volt output and 3600mAH total capacity
    I need to double the current capacity.
    Is it allowed to put 2XAA in parallel with again 2xAA in parallel ?
    Looking forward to replies! If more info needed let me know .
    Points: 19,003, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,665
    19,003
    33
    Re: Setting AA batteries in parallel
    Yes, you can put them in series parallel.
    Do you have room for two C batteries, which have about 3 times the capacity of an AA?
    Zapper
    Curmudgeon Elektroniker
    Points: 14,794, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,461
    14,794
    29
    As long as they are identical batteries, and with the exact same amount of charge(*), I guess they can safely be paralleled.
    (*) This means always replace both batteries simultaneously with same brand, brand-new, fresh batteries.
    But I also second Crutschow's suggestion: utilize a larger battery.
    My batteries are recharged by "Helpful Post" ratings.
    Member level 5
    Dec 2010
    Belgium
    87
    1,642
    9
    Thanks schimtt trigger and crutschow!
