Results 1 to 3 of 3
    Newbie level 2
    Points: 19, Level: 1
    Jun 2019
    19
    Interfacing 16*2 LCD with DE0_nano
    Sir I've interface 16*2 lcd with de2i-150 board but with same working code when uploaded on DE0_nano board its not showing output. Both board have same clock frequency of 50MHz.
    Here is my code:
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    module lcd_test (
                          input clk,
                          output reg lcd_rs,
                          output reg lcd_rw,
                          output reg lcd_e,
                          output reg lcd_4,
                          output reg lcd_5,
                          output reg lcd_6,
                          output reg lcd_7
        parameter n = 27;
        parameter k = 17;
        reg [n-1:0] count=0;
        reg lcd_busy=1;
        reg lcd_stb;
        reg [5:0] lcd_code;
        reg [6:0] lcd_stuff;
        always @ (posedge clk)
        begin
            count <= count + 1;
            case (count[k+7:k+2])
                0: lcd_code <= 6'b000010; // function set
                1: lcd_code <= 6'b000010;
                2: lcd_code <= 6'b001100;
                3: lcd_code <= 6'b000000; // display on/off control
                4: lcd_code <= 6'b001100;
                5: lcd_code <= 6'b000000; // display clear
                6: lcd_code <= 6'b000001;
                7: lcd_code <= 6'b000000; // entry mode set
                8: lcd_code <= 6'b000110;
                9: lcd_code <= 6'h24; // H
                10: lcd_code <= 6'h28;
                11: lcd_code <= 6'h26; // e
                12: lcd_code <= 6'h25;
                13: lcd_code <= 6'h26; // l
                14: lcd_code <= 6'h2C;
                15: lcd_code <= 6'h26; // l
                16: lcd_code <= 6'h2C;
                17: lcd_code <= 6'h26; // o
                18: lcd_code <= 6'h2F;
                19: lcd_code <= 6'h22; //
                20: lcd_code <= 6'h20;
                21: lcd_code <= 6'h25; // W
                22: lcd_code <= 6'h27;
                23: lcd_code <= 6'h26; // o
                24: lcd_code <= 6'h2F;
                25: lcd_code <= 6'h27; // r
                26: lcd_code <= 6'h22;
                27: lcd_code <= 6'h26; // l
                28: lcd_code <= 6'h2C;
                29: lcd_code <= 6'h26; // d
                30: lcd_code <= 6'h24;
                31: lcd_code <= 6'h22; // !
                32: lcd_code <= 6'h21;
                default: lcd_code <= 6'b010000;
            endcase
            if (lcd_rw)
                lcd_busy <= 0;
            lcd_stb <= ^count[k+1:k+0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2)
            lcd_stuff <= {lcd_stb, lcd_code};
            {lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff;
        end
    endmodule
    Points: 5,610, Level: 17
    kripacharya's Avatar
    Dec 2012
    New Delhi
    1,017
    5,610
    17
    Re: Interfacing 16*2 LCD with DE0_nano
    Presumably your compiler/ IDE somehow knows that these are targeted for different boards ? I do not see a directive anywhere in the code published.
    Also to check whether all the pins of the LCD are connected to the correct ports, and that the definitions (lcd_rs, lcd_rw.. etc) are correct for this change.
    Lastly - and this is an error which many users of 16x2 LCD's get tripped on -- is the cursor visible ?
    If not, then probably the trimpot for your contrast control has not been set correctly and you will see nothing.
    Newbie level 2
    Jun 2019
    19
    i've used quartus 2 with latest version and that has specified fpga family. Connection are correct while pot is also working in varying contrast.
