Results 1 to 8 of 8
    Points: 91, Level: 1
    Feb 2019
    91
    Find dc voltage gain and phase margin from graph
    Hi. I want to ask how can i get phase margin and dc voltage gain from the graph? I'm really confused. Hopefully someone can help me with this. Thank you :)
    Member level 3
    Points: 2,107, Level: 10
    Dec 2009
    USA
    54
    2,107
    10
    Re: Find dc voltage gain and phase margin from graph
    Why / how are you confused?
    Do you know what "DC Voltage Gain" means ?
    Do you know what "Phase Margin" means ?
    Points: 24,850, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,759
    24,850
    38
    DC gain is, um, the gain at DC, i.e., zero frequency.
    There is no way to determine phase margin from your graph.
    Points: 264,236, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,170
    264,236
    100
    The graph might allow to determine the phase margin, if it 1. shows the loop gain or can be converted to loop gain by considering a feedback factor and 2. extends to 0 dB gain
    Feb 2019
    91
    Then, can i know what is the right way to find the phase margin? I make mistake on finding the phase margin. Tq
    I am confused whether the gain is at the starting or at -3db from the starting value. And for the phase margin, i make mistake on finding its value. Can i know the correct way to find it from my graph?
    Advanced Member level 2
    Points: 2,889, Level: 12
    Jan 2019
    525
    2,889
    12
    https://www.google.com/search?client...&q=gain+margin
    you need to extend the range of your graphs
    you need to know where the gain graph crosses 0 dB, so the scale has to include 0 dB and you need to extend graph to see where it crosses
    you need to know when the phase graph crosses -180 degrees, so extend the phase scale to include -180 degrees
    you need to extend the frequency range to about 0.1 Hz to get a handle on DC gain
    you need to extend the frequency scale to whatever you need so the gain crosses 0dB and the phase gets below -180 degrees
  7. #7
    barry's Avatar
    Mar 2005
    California, USA
    4,759
    24,850
    38
    Quote Originally Posted by wwfeldman View Post
    You do not need to see where phase crosses -180 degrees; you just need to see where gain crosses zero. The phase margin by definition is the difference of the phase at 0dB and -180 degrees.
  8. #8
    Points: 3,123, Level: 13
    Aug 2016
    548
    3,123
    13
    It seems like your DC gain is about 91dB but we cannot be so sure because your plot is shown from 100kHz. Plot again from 1Hz or 10Hz or even 100Hz.
    We can't tell what your phase margin is because your plot doesn't show where the gain crosses the 0dB line. To obtain tge phase margin, extend your frequency up to 1MHz and measure the phase angle at gain of 0dB.
    Oh! Your plot shows up to 1GHz already. Show the whole range of the plot up to say 100GHz or so.
    --Akanimo.
