Results 1 to 2 of 2
    Newbie level 1
    Points: 988, Level: 7
    Feb 2014
    988
    7
    TimeDesign in innovus with value 0 of Shift Phase
    Hi, All,
    I got an issue with timing report by timeDesign in innovus tool as below:
    Code dot - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    Path 1: VIOLATED Setup Check with Pin u_cortex_a9_mp/u_scu/u_scu_ram/u_scu_ram_
    array/u_tag15/CLK
    Endpoint:   u_cortex_a9_mp/u_scu/u_scu_ram/u_scu_ram_array/u_tag15/CEB (^)
    checked with trailing edge of 'FCLK_CA9_G1_L1_DIV2'
    Beginpoint: se_i                                                       (^)
    triggered by  leading edge of '@'
    Path Groups: {default}
    Analysis View: scan_ss_m40_3s_cworst_m40
    Other End Arrival Time          0.555
    - Setup                         0.244
    [B][COLOR=#ff0000]+ Phase Shift                   0.000[/COLOR][/B]
    - Uncertainty                   0.200
    = Required Time                 0.112
    - Arrival Time                  0.253
    = Slack Time                   -0.141
         Clock Rise Edge                      0.000
         + Input Delay                        0.000
         = Beginpoint Arrival Time            0.000
    the line with red light was supposed to clock cycle, right?
    How should I set some constraint on innovus for this? Thanks.
    Last edited by BradtheRad; 12th June 2019 at 03:55. Reason: Made formatted window for report
    Points: 9,201, Level: 22
    Apr 2016
    1,919
    9,201
    22
    Re: TimeDesign in innovus with value 0 of Shift Phase
    phase shift means that the path is from a negedge to a posedge, for instance, instead of the normal case where paths start at one phase and end at the same phase (posedge to posedge). phase shift != clock cycle.
    also bear in mind that this is not a flop to flop path, it probably is some sort of clock gating path or macro path?!
    Really, I am not Sam.
