Results 1 to 13 of 13
    Junior Member level 1
    Points: 2,389, Level: 11
    Oct 2006
    17
    2,389
    11
    Chossing MOsfet for boost converter
    Hello everyone,
    I have a circuit with one 150watt mosfet
    If I want to double the current load, is it better to parallel the mosfet ?
    OR use a 300watt rated mosfet ?
    Also dont get that a Mosfet can be rates at 150W or 300W or event 600W, and all thre have the same size and (TO 220)
    Sure the heatsink need to be selected accordingly, It this a normal situation with mosfets in general?
    ken
    Points: 30,002, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,949
    30,002
    42
    Blog Entries
    9
    Re: Chossing MOsfet for boost converter
    Switching devices placed in parallel, particularly if not belonging to the same manufacturing lot, it is expected to have discrepancies even though within the specified range, which means that it is not correct to assume that current will be equaly splitted among both, so I would prefer to choose a single Mosfet capable of dealing with a higher currernt.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 80,310, Level: 69
    Apr 2014
    16,294
    80,310
    69
    MOSFETs usually are not selected by Watts.
    Thus it's not clear to me what you call a "150W MOSFET".
    In the datasheet when you read about "Watts" then it usually is the maximum allowed power dissipation.
    For a boost converter you usually don't want 150W (or higher) power dissipation.
    You rather try to keep it as low as possible.
    Advanced Member level 2
    Points: 3,123, Level: 13
    Aug 2016
    548
    3,123
    13
    I'm afraid that this plan of doubling your load current might land you in trouble. First of all, there is a point of concern. How do you intend to double the load current?
    MOSFETs are not selected in wattage but by peak drain current and drain-to-source voltage.
    To be able to get help, you have to list the specification of your converter, like Vin, Vout, frequency, duty cycle, mode of conduction, peak inductor current, and so on.
    --Akanimo.
    Oct 2006
    17
    2,389
    11
    Hello
    I am posting a circuit, the output is at 24 v and about 15 amp so about 360 watt power output.
    Now I have a load of 1050 watt same voltage. I thought of just trippling the mosfets and tripling the transformer size.
    Or just use the equivalent 1050 watt min mosfet power dissipation.
    Ken
    Apr 2014
    16,294
    80,310
    69
    This 24V x 15A = 360W is power supply output power.
    You will never find this value in a Mosfet's datasheet.
    A boost converter is a switching power supply. The Mosfet switcges ON and OFF with high frequencyand varying duty cycle.
    The power loss is mainly
    * switching loss (during each switch transition, it depends alittle on output current, but not that much)
    * and conductive loss ( when the Mosfet is ON, caused by the drain current. It depends on load current and duty cycle)
    For a good 360W output boost regulator the power dissipation in the Mosfet should be less than 30W.
    Doubling the Mosfets won't work. Not only because the gate drive signal will become slower, mainly because the inductor will come into saturation. Causing high currents ... something will get damaged...PCB, inductor, Mosfets, diodes...who knows...
    Buy a power supply rated for your load.
  7. #7
    Points: 12,476, Level: 26
    Aug 2015
    Melbourne
    2,037
    12,476
    26
    look up ON resistance of mosfet at 80 deg C say, multiply this by the RMS current in the fet - squared - i.e. I^2 x R
    then try to estimate the turn off losses and turn on losses - add these 3 to get the power dissipated in the mosfet, hopefully less than 10W for a TO-220.
    Then size a heatsink to give < 100 deg C junction on the mosfet, with the calculated dissipation, say 10W, in this case, for 20C ambient 80degC/10watt = 8 degC per watt - most heatsink catalogs have this number on their parts ...
    good luck ...
  8. #8
    Points: 82,658, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,574
    82,658
    70
    The question is rather like asking "if I fit two engines to my car will it go twice as fast?"
    The answer depends on so many other factors it is impossible to answer but the gut feeling is you need to do a lot more than doubling up on switching capacity, you really need to do a complete redesign.
  9. #9
    Points: 53,548, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,066
    53,548
    56
    Consider interleaving two or more boost converters. By staggering On-times, it lets you operate additional mosfets yet stay within limits.
  10. #10
    Oct 2006
    17
    2,389
    11
    Quote Originally Posted by BradtheRad View Post
    I am going to redesign according to tl494 datasheet.
  11. #11
    Points: 15,240, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,535
    15,240
    29
    Brian's analogy is golden.
    Every car tuner knows that once that you increase the engine power past certain limit, there will be many things that require upgrades.
    From the transmission, to the suspension, to the brakes, tires and everything in between.
    And individually, the engine itself may require a larger radiator and cooling fan, electrical oil pumps and coolers, and so forth.
    In some instance, all that is left from the "stock" car is the sheetmetal.
    My batteries are recharged by "Helpful Post" ratings.
  12. #12
    Aug 2016
    548
    3,123
    13
    Quote Originally Posted by lerameur View Post
    There is no boost converter design guide in the TL494 datasheet.
    --Akanimo.
  13. #13
    Apr 2011
    13,066
    53,548
    56
    Is your initial power source 12V? If so then the step-up ratio is 2 which leads to the option of a voltage doubler based on capacitors.
Name:	555 bias H-bridge 12V 2-cap doubler load 0_8 ohm gets 23V.png
    This simulation demonstrates a concept. Components need to endure tens of Amperes. Gangs of capacitors would be needed. Mosfets can be substituted for transistors.
