Results 1 to 8 of 8
    Points: 6,007, Level: 18
    Jan 2012
    Italy
    1,058
    6,007
    18
    current mirror matching issue
    Dear friends,
    Attached is an image of the simple wide swing current,
    in layout I am matching M1 with M2 in one group, then I match the M3 and M4 separately in other group, then I put M3-M4 above the M1-M2
    My question is, can I put the matched transistors M3-M4 beside the matched transistors M1-M2 ?
    Thank you very much
    Full Member level 1
    Points: 1,388, Level: 8
    Mar 2015
    USA
    111
    1,388
    8
    Re: current mirror matching issue
    That should be fine but you’ll want to keep them close together. The important part is that M1 matches well to M2 and that M3 matches well to M4 and MB. You won’t really be able to place them in the same well if your cascode devices are source body tied anyways. Depending on how precise your matching needs to be, you can either just place them next to each other, or create 2 groupings of the top devices and 2 groupings of the bottom devices (devices+wells/guard rings) and common centroid that. Be sure to use dummy devices as well.
    Edit:
    Not sure what your application is, but if you’re going to be running several mA through the current mirror, I find it’s a lot easier to meet electromigration if you stack them vertically. Create a lot of parallel traces on the lower level metals and cross hatch up to a bigger metal higher in the stack. That helps distribute current evenly and reduce overall stripe current density in the current mirror. At high currents it’s pretty important to make sure that the traces are well matched in the sources of the lower devices.
    Full Member level 5
    Points: 3,129, Level: 13
    nitishn5's Avatar
    Mar 2011
    Bangalore, India, India
    303
    3,129
    13
    Is the reason you want to keep them side by side rather than above-below, because the area you have longer horizontally than vertically?
    -- Bilgotidia Fertiganed
    Jan 2012
    Italy
    1,058
    6,007
    18
    Thank you friends for your reply
    I am using it for small currnt of 50 uA
    The reason is just to fit the space in my layout, otherwise I usually follow the vertical connection
    Advanced Member level 3
    Points: 5,982, Level: 18
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    770
    5,982
    18
    The best option is to keep transistors in stack abutted. It makes layout the most compact in this case.
    Points: 10,293, Level: 24
    Nov 2001
    US
    894
    10,293
    24
    You can abut them but this comes with some limitations. The width of the cascode devices should be the same as the width of M1/2 in order for this arrangement to work. Also, if you have multiple fingers per device it becomes more inconvenient to abut them. So, not unusual to see people organize M1/2 and M3/4 in different groups and just connect them in metal.
  7. #7
    Full Member level 5
    nitishn5's Avatar
    Mar 2011
    303
    3,129
    13
    Actually there is a simple solution for this.
    Assume Mbias W/L = 3/5 (Long Length for matching)
    Assume Mcascode W/L = 1/1 (Some Min Length)
    Use the unit W = 1
    And place the devices in one diffusion of width = 1, Sb-----Db Db-----Sb Sb-----Db Sc-Dc (Each - reperesents 1u Lengh)
    Sb = Mbias Source, Db = Mbias Drain
    Sc = Mcascode Source, Dc = Mcascode Drain.
    To do this you need Odd number of fingers in Mbias and same widths for Bias and Cascode (As long as some sub units have the same widths, that is also good enough).
    With this as a unit, you can do the rest of the matching pattern and not worry about routing between the Bias and Cascode groups.
  8. #8
    Jan 2012
    Italy
    1,058
    6,007
    18
    Quote Originally Posted by sutapanaki View Post
    indeed most of the people are matching them in different groups, you can see the design problem 12.15 in the book of "The art of analog layout". Also in one of your suggestion in other post you have kindly stated that the design constrains for the top transistors are less compared to the real mirror transistors
