[SOLVED] 2coms for my help so that i can do my work and enyoy
drbizzarow
Advanced Member level 1
want to use 2 serial with atmega32 intterupt base .. is it possible ??
is it possible that i can make 2 serial port in 1 atmega 32 ???
How I´d find a slolution:
* Open datasheet: Look how many UARTs are available.
If 2 or more: then there is no problem at all. Use the 2 UARTs
If less than 2: You need to decide:
* use just one UART - maybe multiplexed
* find a microcontroller with at least 2 UARTs
* consider a soft-UART
