Results 1 to 5 of 5
    Advanced Member level 2
    Points: 2,155, Level: 10
    Aug 2016
    570
    2,155
    10
    thermal impedeance junctoin to case
    This transistor does not have max junction temperature listed but has derate value 267mW/C and power dissipation 20W. Is there any way to obtain its thermal resistance junction from case from listed parameters?
    Points: 259,261, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,264
    259,261
    100
    Re: thermal impedeance junctoin to case
    Yes, the derating number is equal to thermal impedance. It's by the way referring to Tj,max of 100°C.
    Aug 2016
    570
    2,155
    10
    Thereby 20watts / 0.267derate = 74.906367 this is over 25c ambient which makes permissible junction temperature at 99.906367C. This is what you were referring to as 100c max?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,264
    259,261
    100
    That's how it works.
    Aug 2016
    570
    2,155
    10
    This particular part doesn't appear to be computable as no derate or junction temperatures are listed however its quite a large transit frequency for such a part, these are typically slow. Can max junction temperature be obtained from only listed parameters?
