Results 1 to 11 of 11
    Newbie level 5
    Points: 322, Level: 3
    Dec 2017
    MG, Brazil
    10
    322
    Voltage inverter feedback for microcontroller (TL431 and 4N25)
    Hello everyone!
    I am trying to develop a feedback system for my sine wave inverter.
    The power is shifted to 12V using a voltage divider, as we can see in the diagram below.
    The intention is to use the TL431 together with the 4N25 to isolate the output circuit of the control circuit to maintain safety and prevent interference from switching.
    However, the prototype was assembled and results were not expected. When the voltage is less than 12V, the TL431 stops conducting the current and the output voltage of the optical coupler goes to 0V level quickly. When the voltage is greater than or equal to 12V the voltage at the output of the optical coupler goes to 5V.
    There is no proportionality of the VFB voltage to the variation at the inverter output.
    Could anyone suggest a tip?
    Using the TL431 together with the 4N25 to isolate the output is the best solution?
    Thank you all.
    Points: 52,329, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,832
    52,329
    55
    Re: Voltage inverter feedback for microcontroller (TL431 and 4N25)
    You have 12v going through 220k ohms (R54). This results in 55 uA which is available to light the led in the optocoupler. It's a miniscule amount. Shouldn't it be more? On the order of 1mA to 5mA?
    Points: 80,565, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,203
    80,565
    69
    I suspect the values elsewhere need attention too. If 1mA was to flow through the optocoupler it would pull the 12V line too low anyway. The 12V line need more current available to it, especially if it has to power other devices as well.
    Points: 258,502, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,134
    258,502
    100
    The ground and isolation scheme looks confusing. I would expect an isolated ground (with a different net name) between bridge rectifier and opto coupler LED side.
    TL431 circuit has a PI characteristic with nearly infinite DC gain. It can only work in a linear feedback loop, if the other loop elements have have suitable transfer function. Additional poles below the loop transit frequency or too large dead time can cause instability.
    Advanced Member level 1
    Points: 2,659, Level: 12
    Aug 2016
    470
    2,659
    12
    How did you come up with the value for resistor R56?
    You should have 1mA flowing through the optocoupler diode biasing resistor and then a reasonable amount (depending on the optocoupler transistor collector current and CTR) flowing through the optocoupler diode itself.
    The maximum value of the resistor is determined by the optocoupler collector current, the optocoupler CTR, the output voltage, the TL431 reference voltage, the optocoupler diode forward voltage, and the optocoupler diode bias resistor current.
    Quote Originally Posted by Akanimo View Post
    ...the optocoupler diode forward voltage...
    This should be the End-Of-Life value.
    --Akanimo.
    Newbie level 5
    Dec 2017
    MG, Brazil
    10
    322
    Hi all!
    First of all, thanks for the kindly reply.
    I made a mistake while drawing this schematic. The schematic is updated to be more cleary.
    The right value for R56 is 220 Ohms. It comes from:
    The smallest amount of current to bias LT431 is 1mA and the voltage of opto LED is approximately 1V.
    So, R(bias) = Vd(opto) / I(bias) = 1V / 1mA: R(bias) = 1K Ohms.
    Also for R56:
    Vout - Vd(led) - ( I(bias) + I(led-eol) )*R56 - V(kA-TL431) = 0V
    Suposing V(ka-TL431) in the end of live equals to 3V, Vout = 12V, Vd = 1V, I(led-end of live) = 30mA and I(bias) = 1mA, we can calculate R56 as:
    R56 = (Vout - V(d) - V(ka) ) / ( (Ibias) - I(led-eol) ) => ( 12V - 1V - 3V ) / ( 1mA + 30mA ) => R56 = 225 Ohms
    R52 and R53 are just a voltage divider for 2.5V TL431 reference.
    Have you guys already seem this approach for isolated voltage feedback using a microcontroller?
    I've searched a lot about this using microcontroller but did not found anything.
    Does anyone have a suggestion about this approach or another suggestion on doing this without using galvanic isolation like another transformer?
    Thanks in advance!
  7. #7
    Member level 3
    Points: 2,053, Level: 10
    Dec 2009
    USA
    54
    2,053
    10
    200K Ohms = R60 + R61
    The ( 4N25 + TL431 ) combined cannot draw more than 1.04 ma through those two resistors !
    How you develop the "12 Volt Signal" from the 220 Volts is very flawed.
    Options:
    a) use a Small Signal Step-Down Transformer to generate the 12 V DC
    b) move all of Voltage Divider resistors into the Feedback circuitry.
    c) use an AC-to-DC RMS IC
    Where did you get that TL431 feedback circuit from?
    And how do you know that it is appropriate for, compatible with, your DC-to-AC Inverter?
    How often, and when during the AC cycle, will the uP sample the 12 V DC Signal?
    You could end up chasing the AC Ripple.
    Many designs regulate the "Intermediate DC Link Voltage" vs regulating the AC Output.
  8. #8
    Newbie level 5
    Dec 2017
    MG, Brazil
    10
    322
    Hi summitvillle!
    Thank you for your reply.
    The ( 4N25 + TL431 ) combined cannot draw more than 1.04 ma through those two resistors!
    Sorry for the wrong voltage scale schematic. I will recalculate that. I just posted the scale for illustration purpose and for everyone understand what I'm talking about.
    By the way, I have tested the TL431 + 4N25 part with a bench power supply regulated for 12V and I didn't get a proportional voltage at Opto output accord to variation of the power supply.
    I have searched in many application notes and made some personal studies about and made a calculated as explained on tread number 6.
    This was one of my questions on the first post and I asked for suggestions as I've never seen an approach like this one for microcontroller feedback.
    The design I'm suggesting does not use High voltage DC link. It uses a heavy transformer to step Up 12VDC to 220Vrms with a filter capacitor on the output.
    The feedback will "look" the voltage at the output at changing the PWM duty cycle accord to the output load.
    I think this is gonna be the best and cheaper solution.
    But I would like to know if the TL431+4N25 is not the best solution for this kind of application using a microcontroller.
    Thanks in advance.
  9. #9
    Points: 76,257, Level: 67
    Apr 2014
    15,468
    76,257
    67
    I'm not experienced with TL431, nor did I go through the datasheet
    But as far as I understand it ... it tries to regulate the voltage at the "control" pin to be constant (wrt anode).
    If so, then I expect that the voltage at the cathode wrt anode will jump somehow and not be smooth.
    --> Use a scope to verify this.
    To make it more smooth, I'd try to add a series resistor in the anode path. Try values 100 Ohms ... 1000 Ohms.
  10. #10
    Aug 2016
    470
    2,659
    12
    You need to show the part of the loop after the optocoupler. Since the loop is not complete, it's impossible to say what's making it not work.
    The only components to the right of the opto that we can't ascertain adequacy right now are the integrator components but downstream of the opto is totally hidden and it is 90 percent likely that that is where the culprit is.
    --Akanimo.
  11. #11
    Aug 2016
    470
    2,659
    12
    Quote Originally Posted by eduardoAvelar View Post
    How did you expect to get it? The loop is for small-signal variations. Loop gain and phase analysis is the way to check this.
    --Akanimo.
