System verilog, fork join_any
surerdra
Junior Member level 1
Can any one please tell me,
Generally the "Fork join_any" is work like, if any one of the internal task can finished, it will non blocked the next statements.
My question is if i taken three tasks in "fork join_any", it has to wait for any two tasks can complete, then only it come out side of fork join_any
how it is ?
If you have tasks a, b, and c then if a takes 10, b task 2, and c takes 5 time units then the fork-join_any will exit when task b finishes (FYI a and c will still run to completion) and continue on to whatever follows the fork-join_any.
In other words the first block that finishes causes the join to occur, hence the name join_any. You can think of the Verilog fork-join as join_all
Here is an example:
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
`timescale 1ps/1ps
module fork_join_any;
localparam ns = 1000;
bit clk;
always #(5*ns) clk = ~clk;
initial begin
  $display ("Starting fork-join_any test");
  fork
    begin
      repeat (10) @(posedge clk);
      $display ("Finished repeat (10)");
    end
    begin
      repeat (4) @(posedge clk);
      $display ("Finished repeat (4)");
    end
    begin
      repeat (7) @(posedge clk);
      $display ("Finished repeat (7)");
    end
  join_any;
  $display ("Exiting fork-join_any");
  repeat (8) @(posedge clk);
  $display ("Finished fork-join_any test");
  $finish;
end
endmodule
Which has the following output:
# Starting fork-join_any test
# Finished repeat (4)
# Exiting fork-join_any
# Finished repeat (7)
# Finished repeat (10)
# Finished fork-join_any test
# ** Note: $finish    : fork_join_any.sv(38)
#    Time: 115 ns  Iteration: 1  Instance: /fork_join_any
# End time: 08:03:23 on Jun 04,2019, Elapsed time: 0:00:06
# Errors: 0, Warnings: 0
You will need to use a semaphore
[FONT=Courier New]semaphore s;
s = new(0);
fork
   begin : process1
    s.put(1);
   end
 begin : process2
    s.put(1);
   end
 begin : process3
    s.put(1);
 end
join_none
s.get(2);
disable fork; // kills remaining process
s = null; // removes semaphore (if you plan to reuse s)[/FONT]
the semaphore method is good
Thank you
