Results 1 to 11 of 11
    Junior Member level 3
    Points: 322, Level: 3
    Jul 2018
    27
    322
    hardware issues in simple interrupt code p16f887 using mikroc
    dear seniors,
    I want to write a program on IR sensor using NEC protocol, for that i just started to understand basic codes of interrupt. Just blink an led port when interrupt is occurred. Wrote a coding n executed in proteus too. But when try to implemented in hardware mode the interrupt part is not working. I was tried my best to solve the issue, but failed all times. Here i am attaching my source code and simulator file and photos of my hardware. Kindly suggest what went wrong exactly.
    Micro controller - pic16f887
    platform - mikro c.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    void interrupt()
         if(INTF_bit)
            PORTA=0X00;
            delay_ms(3000);
            INTF_bit=0;
    void main()
            ansel = 0x00;
            anselh = 0x00;
            TRISB0_bit=1;
            TRISA=0X00;
            OPTION_REG=0X40;
            INTCON =0X90;
            RBIF_bit = 0;
            OSCCON = 0X70;
            IOCB0_bit = 1;
            while(1) {
                    PORTA=0xFF;
    Points: 79,067, Level: 68
    Apr 2014
    16,051
    79,067
    68
    Re: hardware issues in simple interrupt code p16f887 using mikroc
    As said many times: "the interrupt part is not working" is no error description.
    * Say how your test setup looks like
    * Say what you expect
    * Say what you see instead
    * say what you did so far to debug the problem
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    Jul 2018
    27
    322
    klaus,
    1. I already attached my development board.
    2. I want to decode IR remote of NEC protocol. For that I got a code from web. While testing the code i found that interrupt part is not working. Then i decided to test the interrupt with a simple LED blinking code. It works well in simulator but the while doing the same in harware found that same interrupt part is not working.
    3. when you apply voltage to MC PORT A LED goes high as written in code, but when i applied interrupt at B0, it doesn't blinking.
    4. I tried to add/modify register of INTCON, OPTION_REG, and even OSCCON for setting internal oscillator. Nothing works so far.....
    also added 10k resister to B0 to ground.
    Advanced Member level 2
    Points: 3,283, Level: 13
    baileychic's Avatar
    Aug 2017
    651
    3,283
    13
    Don't use IOCB0_bit, instead use INTE_bit and INTF_bit.
    Enable INTE_bit, PEIE_bit, and GIE_bit before the main loop.
    In ISR test for INTF_bit.
    RB0 pin has to be used.
    Jul 2018
    27
    322
    baily,
    Couldn't able to enable INTCON register before main loop, its showing error as "identifier refined".
    I already tested INTF_ bit in ISR and I used RB0 pin sir..
    Kindly suggest how to enable them before main loop..
    baileychic's Avatar
    Aug 2017
    651
    3,283
    13
    Try this code.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    void interrupt() {
        if((INTE_bit) && (INTF_bit)) {
            PORTA = ~PORTA;
            INTF_bit=0;
    void main() {
        OPTION_REG = 0x8F;
        ANSEL = 0x00;
        ANSELH = 0x00;
        TRISA = 0x00;
        TRISB = 0x01;
        INTF_bit = 0;
        INTE_bit = 1;
        INTCON = 0xC0;
        while(1) {
            asm clrwdt
  7. #7
    Jul 2018
    27
    322
    Tried your code, But its not working in simulator itself.
    i have attached the project with this, kindly check and reply.
    Quote Originally Posted by venthan View Post
    1. Your code is now working,
    2. Made two changes, 1. INTCON register value is 0x90.
    2. Added delay in ISR.
    Now its working in simulator, I will try to implement in hardware and update you.
  8. #8
    baileychic's Avatar
    Aug 2017
    651
    3,283
    13
    INTEDG_bit was also missing in the code. I added it.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    void interrupt() {
        if((INTF_bit)&&(INTE_bit)) {
            PORTD = ~PORTD;
            INTF_bit=0;
    void main() {
        OPTION_REG = 0x8F;
        ANSEL = 0x00;
        ANSELH = 0x00;
        TRISD = 0x00;
        TRISB = 0x01;
        PORTD = 0x00;
        INTF_bit = 0;
        INTEDG_bit = 0;
        INTE_bit = 1;
        INTCON |= 0xC0;
        while(1) {
            asm clrwdt
  9. #9
    Jul 2018
    27
    322
    yes sir, i already made OPTION_REG = 0xCF;
    In hardware mode -----> should i enable WDT in configuration?
  10. #10
    baileychic's Avatar
    Aug 2017
    651
    3,283
    13
    If you need WDT to be enabled then enable it else just disable it in project settings.
  11. #11
    Jul 2018
    27
    322
    Quote Originally Posted by baileychic View Post
    Yes Sir, Implemented in Hardware and its working fine now. Thanks for your guidance.
