Page 1 of 2 1 2 LastLast
Results 1 to 20 of 38
    Full Member level 1
    Points: 693, Level: 5
    Jan 2018
    99
    693
    Confused - transmission line component in Virtuoso and ADS
    I am learning to design matching network with distributed elements. Usually when we design stub matching, we get the line lengths from smith chart. Now when I look at TLIN in ADS it has parameter E(electrical length) and TLINE in virtuoso has delay time. In ADS's smith chart utility also angle (I guess it is electrical length ) is given when stub or line are chosen as matching element. I know there are mathematical relations among these parameters but I am confused why they are not consistent. Someone please clarify. Thanks
    Points: 15,723, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    Re: Confused - transmission line component in Virtuoso and ADS
    Quote Originally Posted by circuitking View Post
    Cadence Virtuoso is a Design Framework.
    This does not make sense at all, even if you mean "analogLib/tline".
    Use correct terminology.
    "analogLib/tline" is a just symbol.
    It is used by various simulators, e.g. Keysight ADSsim, Synopsys HSPICE, Cadence Spectre, etc.
    What simulator do you use from Cadence Virtuoso ?
    You can use Keysight ADSsim from Cadence Virtuoso.
    If you mean Spectre Primitive, "tline", it is derived from SPICE which is oriented for signal delay originally.
    That's all.
    HSPICE Syntax
    Ideal T-element Transmission Lines
    Syntax
    General form:
    Txxx in refin out refout Z0=val TD=val [L=val]
    + [IC=v1,i1,v2,i2]
    Txxx in refin out refout Z0=val F=val [NL=val]
    + [IC=v1,i1,v2,i2]
    Also see "spectre -h tline".
    On the other hand,
    TLIN (Ideal 2-Terminal Transmission Line)
    TLIN4 (Ideal 4-Terminal Transmission Line)
    in ADSsim are oriented for RF application.
    Full Member level 1
    Jan 2018
    99
    693
    Quote Originally Posted by pancho_hideboo View Post
    I am using spectre simulator but mostly I never used HSPICE syntax or something, I only use GUI.
    I see so analoglib/tline is used, if I want signal delay. Actually I am solving the from boook Microwave Transistor Amplifiers analysis and design, 2nd edition by Guillermo Gonzalez. So I am stuck on how to solve it using smitch chart utility in ADS to find those line length and implement the schematic in Virtuoso.
Name:	example 2_5_2.JPG
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    I only use GUI.
    What do you want to mean ?
    Surely see "spectre -h tline".
    Fisrt of all, what is your operating frequency ?
    Attached figure is Spectre Syntax.
    Specify z0, f and nl.
    Full Member level 1
    Jan 2018
    99
    693
    Let's take 1 GHz.
    Points: 256,580, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,769
    256,580
    100
    You didn't yet clarify where you see inconsistency of different parameters (electrical length, delay, phase angle) used to describe transmission line circuits. As you state, they are clearly related.
  7. #7
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    His purposes are satisfied if he set z0, f and nl instead of z0 and td for Spectre Primitive, “tline”.
  8. #8
    Points: 13,173, Level: 27
    Apr 2014
    2,041
    13,173
    27
    It's based on users needs. ADS users are usually RF designers, so they don't think in terms of delay time. That's why ADS ideal line models are based on phase delay at a given frequency.
  9. #9
    Full Member level 1
    Jan 2018
    99
    693
    Quote Originally Posted by volker@muehlhaus View Post
    This makes sense, So I always need to convert from electrical length (EL, found in smith chart utility) to physical length(EL*lambda/360) and use it in analogLib/tline.
    Thanks, your comments are valuable. is this normalized electrical length equal to electrical length ( in terms lambda)/ lambda ?
    Finally, I understood there are three parameters ..
    1.Electrical length (in terms of lambda)
    2.Electrical length (in terms of angle)
    3.Physical length
  10. #10
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    This makes sense,
    Physical length is not required at all in Spectre Primitive, "tline".
    Yes.
    nl is len/lamda.
    lamda=vel*c/f
    td=len/(vel*c)=nl*lamda/(vel*c)=nl/f
    Spectre Primitive, "tline" does not have this.
    angle=360*f*td
    Attached figure is "analogLib/tline" for ADSsim not Spectre.
  11. #11
    Apr 2014
    2,041
    13,173
    27
    circuitking mentioned ADS TLIN model, which of course has electrical length parameter
  12. #12
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    ADS TLIN model does not have the followings.
    3.Physical length
    Spectre primitive have
    3.Physical length
    ADS TLIN model have the followings.
  13. #13
    Apr 2014
    2,041
    13,173
    27
    You're a genius. That is how ADS is designed: it uses different line models for electrical and physical parameters: TLIN and TLINP.
  14. #14
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    MDS which was one of ancestor of ADS was frequency domain simulator originally.
    This is true for Libra.
    Transient Analysis was introduced at MDS-5.0 first.
    So TLIN and TLIN4 are oriented for frequency domain.
    Of course, they are effective in time domain.
    ADSsim can read HSPICE and Spectre netlist directly.
    Here SPICE primitive “tline” is converted to ADS primitive “TLIN4” internally.
    See http://literature.cdn.keysight.com/l.../Txxxxxxx.html
  15. #15
    Full Member level 1
    Jan 2018
    99
    693
    Hi, I have to visit this again. I have done a few examples and they gave me correct results but this particular one is displaying wrong input impedance. I hope I am not sharing any sensible information, this example is also taken from the same book I've mentioned above. I should get 15+j30 ohm but I got 15.6-j15.6 at 40 GHz.
    I want to know whether the way I have connected the Tline is correct for the stub and why I didn't get 15+j30 ohm.
  16. #16
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    Your connection is completely wrong as open stub.
  17. #17
    Full Member level 1
    Jan 2018
    99
    693
    I see. This time I got 15.22+j30.48. I realized that I made a mistake short stub also. For example, If it is a short stub, I should connect X and Y (In the figure) correct?
  18. #18
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    Still completely wrong.
    Surely consider relation between TLIN and TLIN4 of ADSsim.
    No.
    Before considering short stub, surely understand correct connection as open stub.
  19. #19
    Full Member level 1
    Jan 2018
    99
    693
    I know I didn't get exact 15+j30 ohm but I am still wondering what changes I need to make in connections to have correct open stub
    To be frank, I don't even know why there are TLIN and TLIN4 and their purposes. I could only find this information http://edadocs.software.keysight.com...ine+Components
  20. #20
    Oct 2006
    Real Homeless
    2,397
    15,723
    30
    TLIN is only for single-ended.
    TLIN4 can be used for both single-ended and differential.
    Surely see and understand equation of “spectre -h tline”.
